How to prepare for extreme cold conditions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DianeMN, Jan 4, 2018.
Tags:
  1. DianeMN
    DianeMN New Member
    Hi. I just discovered this forum, while searching for advice on starting in very cold weather. I'm heading up to northern Minnesota later this month, where temps have dipped to -30F recently. So I'm wondering how to best prepare for potentially extreme cold. Here in Mpls I keep my 2014 Prius in a garage, but I won't have a garage up north. I won't need to use my car for the 3 days I'm there either.
    I've read about grill blocking which I haven't heard of. And I've learned there is a 12v battery, which is the battery that can be trickle charged or jumped if necessary. This is my first Prius, so things work differently than pmy previous cars... Any advice appreciated on how to avoid ending up with a car that won't start, far from home, in potentially extreme cold. Thanks!
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    662
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Keep in mind the traction starts the car, not the 12 volt battery. I would think you would have less of a problem starting, as there is more battery to start the ICE. The 12 volt is just for the computer and accessories. (I think)
    51,155
    welcome!
    grille blocking will improve your mpg's but do nothing for sitting 3 days in 30 below weather. will there be a plug available for a battery tender on the 12v?
    people in those climates often have engine block heaters. but it wouldn't be worth it for 3 days.
    make sure your oil level is correct and fill the car with fresh gas.
    make sure you have all the requisite emergency supplies in the car including food and water.
    check the spare and all tire pressure, and confirm jack and tools.
    Chodronish and DianeMN like this.
  4. bat4255
    662
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Block heater?
    DianeMN likes this.
  5. Mendel Leisk
    40,584
    It's too bad they don't just slam in the block heater at the factory, the (wholesale) cost is trivial, and access is SO much easier. The one positive to post-factory install: at least you don't have to drain the coolant with a Prius. Dealership should be able to put one in for $200~250. It's not a fun DIY.
    We got the block heater when taking delivery of the car, use it year round. On the balmy west coast.
    A smart charger (4 amp range) plugged in overnight, besides charging the battery, does it also help keep it from freezing? I'm a little foggy on that.
    And you should be safe to grill-block the lower grill 100%. Two of the four foot long by 1.5" Outside Diameter foam tubing (plumbing pipe insulation, with the slits) pushed over the slats and secured with whatever at both ends, will accomplish this easily. I secure ours with velcro tape, easy to remove/adjust.
    If temps get above freezing I would take one tube out (makes it 50%), and if doing some sort of sustained hill-climb, say up a ski mountain, take it all out.
    The upper grill can be blocked up to 50%, but it's tricky: the inverter radiator is behind there. Best to just leave it open.
    You can also push pieces of foam tubing on the crimped seam at edge between fender and hood, to tighten up the engine bay a little. I do that and leave it in year-round, no problems.
    #5 Mendel Leisk, Jan 4, 2018
    DianeMN and bisco like this.
  6. bisco
    51,155
    yes, a fully charged battery will freeze slower. don't know the chemistry.
  7. Mendel Leisk
    40,584
    Grill block and engine bay sealing:
    The above is one 4' piece, pushing it's slit onto the grill slat and secured, with a reusable velcro tape to secure it. This amounts to 50% block. Put a second tube below: you have 100%. IMG_8108.JPG
    This is one zone that doesn't have a gasket. Putting the foam along this seam (again, just push it on, using the slit on the foam tube), seals the heat in the engine bay better.
    #7 Mendel Leisk, Jan 4, 2018
    Chodronish, DianeMN and bisco like this.
  8. Tideland Prius
    16,445
    The nice thing about a Prius is that it can withstand colder start-ups more easily than regular cars.
    When you start a non-hybrid, the 12V battery cranks the starter motor which then has to start pumping the engine's pistons before the engine fires up. You can imagine it puts a strain on the alternator and 12V battery if the engine is cold and stiff.
    In the Prius, you are literally turning on the computer. The 12V battery will turn on the electronics and there is no starter motor. The electric motors (which are far more robust than an alternator) will fire up the engine. Sometimes immediately, sometimes a few seconds after you turn on the car. The result is lower stress on the 12V battery. It's also why the 12V battery in your Prius is smaller than a regular car.
    But in terms of cold start, it's not ideal but as long as your 12V battery is in good condition, you don't have to do anything after the 3 days and it will start.
    But if you want to try and maintain mpgs, grille blocking helps by stopping air flow from entering the radiators, thereby reducing the cooling effect when you drive. This helps the engine warm up faster.
    An engine block heater will also help reduce wear and tear as it pre-heats the engine core, allowing for a smoother start and smoother running engine. Combined with the grille blocking, it can help bring heat into the cabin faster as well as allow for earlier shut down of the engine to reduce fuel consumption.
    Grille blocking just involves installing foam pipe insulator (I use 1/2"... then sliced lengthways to create two u-shaped pieces that will be squeezed into the gaps in the lower grille). You can use zip ties to hold them in place if you're worried they may fly out on the highway. I would not recommend blocking more than 50% of the upper grille. (I usually keep the upper grille open and only block the lower).
    You can keep the lower grille 100% blocked to about 32°F and then use 50% blocked until about 50°F.
    Oh and ensure your tire pressures are properly adjusted (and accounted for the difference in temperatures). It's about 1 psi change for every 9-10°F.
    #8 Tideland Prius, Jan 4, 2018
    Chodronish, DianeMN and dubit like this.
  9. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Basically just don't leave lights on, don't sit in the car listening to radio for hours while car is not in ready
    And better worry about your doors freezing shut, so use silicone on the rubber
    Oh, and definitely watch out for poor diesels trying to start :)
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Nomenclature clarification just to avoid confusion for a newbie. The alternator in a regular car charges the battery and is driven by the engine via a belt. The starter motor cranks the engine using a gear engaged with the flywheel gear. Otherwise, a great description. (y)
  11. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Never had a problem with either Prius in cold weather, and never had any luck with the block heater in Pearl. Useless at -20C and below. Don't even have one of these useless devices (for -real- winter places) in Pearl S. Don't miss it. They are simply not powerful enough and can't be powerful enough. They would overheat. It appears no manufacturer wants to use a proper block heater anymore (that goes into a "frost plug" and is immersed in coolant) and is at least 600W, sometimes as much as 1000W. They work.
    I have all the lower grill blocked. Works great at ensuring the engine gets at least partially warm in the city (I see the coolant at 50-65C most of the time). On the highway the coolant can actually reach operating temp. (85-90C). I leave the upper grill open.
    If the Prius can't start the engine with the traction battery NOBODY will be moving! As long as the 12V battery gets you to "ready", of course.
    DO make sure your engine and inverter coolant is not diluted (nobody added just water) and you'll be fine.
    Modern fuel with "up to 10% alcohol" ensures you won't need fuel line antifreeze.
    When charged the 12V battery has a higher concentration of sulfuric acid and would freeze at a much lower temperature than you will experience. When discharged fully it can freeze at -30F. Don't allow it to fully discharge. For a three day stay you shouldn't have a problem.
  12. Tideland Prius
    16,445
    Thanks! I'll make the change in my post.
    I forgot one more thing (David jogged my memory). Ensure your washer fluid is rated for the lower temperatures. There are some that go to -30°C and some to -40°C. Ensure to have the lower one in case you need to use it.
  13. Mendel Leisk
    40,584
    David, I've had both coolant immersed (previous Honda) and current indirect style block heater with Prius, both work well, raise coolant about 25C above ambient, give you a head start on warm up.
  14. ChapmanF
    17,347
    You can take along one of the small, not much more than deck-of-cards sized, lithium-ion jump packs ... not because there's any great likelihood you'll have battery trouble, but because just in case you do, it's likely you won't want to stand around very long soaking up the breezes and waiting for a jump.
    You could even end up using it to jump somebody else.
    -Chap
    Chodronish, DianeMN and WilDavis like this.
  15. drysider
    drysider Active Member
    823
    335
    Liberty Lake WA
    Depending on how long the -30 temps will last, I would seriously consider leaving the car in Ready mode and setting the interior temperature to 68F or so.
  16. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Yes, keep the 12 volt topped off, driving there should do, if you have a trickle charger, just to be sure.
    When I first met my wife in central NYS, she drove a 6 volt vw, winters were brutal, she lived in a trailer and at night would drain the oil, put it on the wood stove and in the morning put it back in the car, that’s as hard core as it gets, but she always started...., so, 30 below for a few days, even a light bulb under an emergency blanket (thin foil) would warm up everything. ( I used to in those days)
    DianeMN likes this.
  17. bisco
    51,155
    earth to diane?:p
    DianeMN and Mendel Leisk like this.
  18. Mendel Leisk
    40,584
    Number one on my list: warm and waterproof gloves.
    I don't think I could survive there, get frostbite like blisters on my fingertips every winter, on the balmy west coast.
    WilDavis, DianeMN and bisco like this.
  19. farmecologist
    farmecologist Senior Member
    1,956
    1,798
    Southern MN
    Daughter and myself drive our 2010. She has left it outside in -15F to -20F a few times and it started like a champ. Frankly. the Prius does much better in cold weather than many ICE-only cars do. With that being said, I do leave a battery pack jump starter in the back...just in case.
    I'll also admit that I don't do much maintenance during the depths of winter. I wait as long as I can in the fall to do the final pre-winter maintenance chores and then let it go until spring. It has never been a problem...we don't drive enough in the winter to go past our usual oil change interval.
    DianeMN, Raytheeagle and Mendel Leisk like this.
  20. ChapmanF
    17,347
    Lucky you ... I've been letting the Gen 3's built in oil change timer remind me when to do oil changes, and of course it has picked this week.
    I've been putting it off for some reason. Maybe next Thursday, when it's above freezing. Have to show these cars who's in charge.
    -Chap
