How to prevent engine from starting and put it in neutral
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by different.eli, Jan 25, 2024.
Tags:
  1. different.eli
    different.eli New Member
    Vermont
    Do to possible hydrolock i need to pull the spark plugs. It would be nice to move the car to a more convenient work location by putting it in neutral and pushing it since i have to remove the windshield cowl to pull the plugs. So i need to turn the car on to put it in neutral but Cannot Risk at all having the engine start during that time.
    Upon reading other posts it looks like i can "Pull the AM2 fuse from the underhood fusebox" which will prevent the engine from starting but will i still be able to put the car in neutral? (yes i need to figure this out before i get to the car, it's not accessible yet)
    Or is it possible to manually force the car into neutral but pushing a lever, or such, under the hood or from underneath the car?
    Thanks for your time,
    Eli.
    Preventing a Prius from starting | PriusChat
  2. KMO
    KMO Senior Member
    1,521
    401
    Finland
    2023 Prius Prime
    You can put a Prius into neutral when it's in ON mode (rather than READY), and it can't start the engine then.
    Press the POWER button twice without foot on the brake pedal to get to ON. Then you can shift to N.
    QuantumFireball likes this.
  3. Mendel Leisk
    38,657
    What’s the miles on it?
  4. vvillovv
    vvillovv Senior Member
    3,615
    1,272
    NY
    If, the prius you're asking about is a Plugin like the one shown in your profile, and everything else in the car is working normally, the default READY mode at startup is EV mode. Double check that all accessories are off while in ON mode, especially the HAVC system.
    If you want to experiment a bit you can also remove the spark plugs, than see what is shown when you push the start button a few times both with foot off the brake pedal and foot on the brake pedal.
    Might also want to learn how to remove any coolant that might be in the cylinders, while spark plugs removed.
  5. ChapmanF
    15,494
    This is a moment for Westheimer's observation, a coupla months in the laboratory can save you a coupla hours in the library, only for this question of course nowhere near that kind of time is needed.
    The owners' manual already flat-out tells you what happens when you push the button once with no brake, twice with no brake, and once with brake, and that information is worth memorizing so you know it in your sleep without having to experiment.
    Once with no brake is ACC, and the radio works, and a few other things like the power outlets.
    Twice with no brake is ON, and all the ACC stuff works plus the instruments, and you can shift between P and N.
    Once with the brake is READY, and you risk the engine starting.
    KMO likes this.
  6. vvillovv
    3,615
    1,272
    NY
    So sorry you didn't like my alternative suggestions for a owner worried about hydro\locking if his engine starts.
  7. vvillovv
    3,615
    1,272
    NY
    sorry, I thought that knowing it's still there would be a good enough clue that maybe someone else would be able to find it too. Keepin my fingers crossed that it will stay that way (available) at least for a little while longer . I did have to re read the license agreement -before.
