how to prevent mice from getting in to glovebox
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by dk_brookdale, Aug 19, 2021.
Tags:
  1. dk_brookdale
    dk_brookdale Junior Member
    66
    I know the topic of rodents causing problems with the Prius has been brought up many times on priuschat but I cannot find the exact information I need when doing a search. A few times a year I clean out nesting created by mice in area adjacent to glovebox where cabin filter and a squirrel cage fan are. After I clean it out they just come back. What I want to know is this - where exactly (and how) are the rodents getting in? And how can I block their entry on my 2012 Prius V so they cannot get in?
  2. Mendel Leisk
    42,315
    Take off wipers and cowl; install 1/4” galvanized steel rodent mesh over cabin air intake. Hold it in place with a few sheet metal screws; pre-drill holes for the screws.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    Don't put snacks in the glove box.;)
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Tiny mice handcuffs. :p
  5. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    How about tiny hands, like someone we know to put them on.:eek:
  6. dk_brookdale
    66
    I had done that in the past but not recently. The mice seem to be looking for safe place to nest and not necessarily something to eat.
  7. dk_brookdale
    66
    I think that might be a solution, thanks. I will try that. Don't see how the mice could get into that cowl/air intake area. But if I install the rodent mesh as recommended it's unlikely they'll be able to get through to the glovebox area.
  8. Mendel Leisk
    42,315
    For wiper/cowl removal tips, @NutzAboutBolts video on spark plug change is invaluable. I think v is sim enough too?
  9. dk_brookdale
    66
    I subscribed to NutsAboutBolts on youtube and searched through all his videos. I could probably figure out how to do the mesh procedure you recommend. But I'd appreciate getting the link to wiper/cowl removal if you could find it, thanks.
  10. ChapmanF
    18,999
    They get into the cowl area the same way the rainwater gets out.
    When I did a similar preventive thing on my dad's Hyundai, I didn't use sheet metal screws, I just scuffed the paint around the heater opening some, put a bead of mixed epoxy around it, and sank the galv mesh into that. But if I remember right, the access was much harder on that car, which didn't have a removable cowl. That might have been the way I had to do it.
  11. Mendel Leisk
    42,315
    There’s convenient links to his videos here, in a thread pinned at top of 3rd gen maintenance forum.
  12. Makaru
    Makaru Junior Member
    51
    2013 Prius v wagon
    We had that problems. Sanitized inside of car and put essence of peppermint in several spots in the engine bay and inside the car. Apparently mice hate that smell
    Never saw them again.
    fotomoto likes this.
  13. HB-Prius
    HB-Prius Junior Member
    17
    Orange County, CA
  14. HB-Prius
    17
    Orange County, CA
    I closed out the openings with 1/4" Wire Mesh as shown in attached photos and I still have mice getting in. Does anyone know about keeping the recirc option on to keep the door to outside air closed? Can't get photos to upload...............
  15. Mendel Leisk
    42,315
    where did you mesh; the opening you have to remove wipers and cowl to get to? That’s the main one, and when it’s securely meshed I can’t see them getting into cabin. Unless they manage to get in via the hybrid battery vents, way at the back. But then you’d likely see “evidence” back there as well.
