How to recalibrate the fuel gauge
Discussion in 'Gen 2 Prius Main Forum' started by ToyotaGal, Jan 25, 2021.
  1. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    Can a moderator please make this a sticky note so it is always easy to find? Also can you add that a driveway is not a flat surface. Garages, the pump area or a mechanic garages are all flat areas.
    Tia
    PriusCamper likes this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    I don't see any useful information in there.
    None of what you said is necessarily true.
    A flat surface can be determined with a simple tool called a LEVEL.
    49,553
    how do you recalibrate the fuel gauge?
    i second the sticky!
  4. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    It is very useful to have a sticky note on how to re-calibrate as there are a lot of false videos up on you tube.
    It is true that a level can determine if a surface is flat.
    I was told that driveways are not flat otherwise water would collect there when it rains. So before you re-calibrate, check with a level.
  5. sam spade 2
    7,035
    2,790
    2017 Prius c
    BUT.....there is NOTHING in this thread that actually tells how to do that.
    IF......there is another thread that DOES have that information in it, you should have posted your message as a reply on the end of THAT thead. Understand ?
  6. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    sorry for the misunderstanding. i am asking the moderators to post the correct instructions on how to do it. There are too many versions of it out there.
    and to make it a sticky note so we can find it.
  7. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    I've never used the following link, but it should contain *everything* you need : Service Manuals - Google Drive
    It would be great if someone could extract the manuals from Gdrive and back them up on http://mega.nz/ as well.
  8. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
  9. sam spade 2
    7,035
    2,790
    2017 Prius c
    And that leads to a second "misunderstanding".
    The Moderators are not necessarily qualified experts in every aspect of vehicle maintenance.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Toyota gal you were quite clear asking for a sticky to be made to reference a calibration.
    other car forums have a section called
    BODY OF KNOWLEDGE with titles of info.
    We do have a search function though but a BOK is more useful.
    For this G2 section headers could be:
    FURL GAUGE CALIBRATION
    INVERTER PUMP
    HARD TO FUEL A G2 & GAS TANK ISSUE
    THE MYSTERIES OF THE 12 VOLT BATTERY
    HOW TO JUMP START A G2 & THE DANGERS OF THAT
    HYBRID BATTERY FAILURE
    PRIUS INSPECTION MODE
    WHEEL BEARING FAILURE
    etc.
    Each title woukd have definitive info & pictures & part numbers and watch out fors.
    instead we have millions of the same question over and over and over again.
    ColoradoCrow and SFO like this.
  11. fuzzy1
    10,189
    Moderators are not compelled to be content producers. I don't think they are paid enough to have that responsibility. :)
    Usually someone else produces and posts such content, then moderators decide how to manage it and which posts should be turned into stickies or features. So feel free to make or find the content that you believe deserves being turned into a sticky note.
    ColoradoCrow likes this.
