How to Remove Bottom of Rear Seat
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Oswaldo, Oct 21, 2005.
  1. Oswaldo
    Oswaldo New Member
    25
    SF Bay Area
    I purchased a set of GT Covers for the rear seat of my '05 Prius. Installing the covers for the seat bottom requires running some straps underneath. Is there a release or does it need to be unbolted? Where?
    Thanks in advance for your help.
    Oswaldo
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I'm pretty sure you can just grab rear-most portion of the seat and lift it forward. Might be hinged on somewhere, but should be easy to get out, if still necessary, once the back is lifted up.
  3. Oswaldo
    Oswaldo New Member
    25
    SF Bay Area
    Thanks, Doc. It appears that there is a bolt securing the back of the seat. I didn't try removing the bolt - I was able to lift the cushions enough to pull the straps through.
    I wish I had the service manual.
    Oswlado
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Sounds like you've solved your problem, but the rear bottom cushion is removed by yanking the FRONT of the seat up. It's clipped in, so to put it back, slide the back end in and push the front down. EASY!
  5. mhiatt
    mhiatt New Member
    Colorado
    I just did my backseat with Wet Oakley covers. The back seat bottom is removed by simply pulling up at the front. There are two clips in the front, one on each side. After that, there is a one center tab at the back of the seat which is removed by applying pressure down and then out (forward). Hope this helps.
