How to remove broken needle from inside windshield nozzle?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Garethh, Aug 7, 2015.
  1. Garethh
    Garethh Junior Member
    38
    Newport Beach, CA
    Hi!
    I broke a needle inside one of the holes in one of the windshield nozzles. Call me ocd but it's really bugging me. I have to remove it somehow. I sprayed it with wd40 so it wouldn't get rusted in there. I tried a strong magnet but no go. I could use any suggestion as to how i can remove it.
    Thanks!
    51,155
    it doesn't come out when you hit the washer button?
    did you try a magnet?
    might have to remove the nozzle to turn it upside down.
  3. Garethh
    38
    Newport Beach, CA
    How do I remove the nozzle?
  4. JC91006
    16,674
    8,519
    if it bothers you that much, just replace "both" nozzles. that way it'll spray correctly onto the windshield and not over your car
  5. Garethh
    38
    Newport Beach, CA
    I am trying to avoid spending money for now. Besides, i don't know how to remove the nozzles to start with. If i could, it would make removing the broken needle so much easier.
  6. JC91006
    16,674
    8,519
    it should be accessible under the hood. take off the insulator and you'll see the 2 nozzles. just be careful you don't break the clips when you remove them.......chances are they will break since it's from 2006
  7. Garethh
    38
    Newport Beach, CA
    I will try it right now. What should i do not to break the clips?
  8. JC91006
    16,674
    8,519
    maybe you should wait until you buy new nozzles? they are not that expensive and they'll help your OCD because it'll all work properly.
    I don't know how to prevent you from breaking clips......plastics get brittle as they age, and it's 9 years old now
  9. bisco
    51,155
    be as gentle as possible. visually, try to understand how the clips come off, before proceeding, so you won't be forcing them. spray the with some lube beforehand?
  10. Garethh
    38
    Newport Beach, CA
    I tried but couldn't do it with the tools i have. :/ It's hard to put pressure to the clip from both sides and pull at the same time. I need a third hand.
  11. bisco
    51,155
    local gas station?
