How to remove front seat floor bolts in 2024 Prime XSE Premium
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Rordon Gamsay, Mar 17, 2024.
  1. Rordon Gamsay
    Rordon Gamsay New Member
    Alabama
    2024 Prius Prime
    XSE Premium
    New to this, question in title.
    Tried removing driver front seat floor bolts today with a T50 and a socket wrench but it wouldn't budge. Does it have thread locker? Can I use WD-40? Any way without using heat? Do I need an impact tool to remove it? Scared of breaking something or stripping it.
  2. N79PT
    N79PT Junior Member
    37
    Sonoma County
    2024 Prius Prime
    SE
    Why? (Just curious)
  3. Kenny94945
    Kenny94945 Active Member
    780
    397
    Sausalito
    2016 Prius v wagon
    2 cent comments.
    Is there a nut that should be remove from under the car?
    For my memory, I don't recall many front seat attachments being bolts, that thread into a floor pan/ metal.
    As for heat, if blue Loctite, you could safely try a heated soldering iron place on the bolt head or shaft.
    And from memory toque is usually around 35 ft lbs.....and counter clockwise to loosen :) is the standard.
    Best guess, look under the car at the attachment and/ or search for a parts diagram.
    Good luck.
  4. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    Careful, those are safety items.
    To guarantee proper performance in a collision they need to be torqued pretty precisely. I don't happen to know the rules for bolt re-use.
    The answers to all of that and more...
  5. Hammersmith
    Hammersmith Senior Member
    1,301
    1,321
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The OP removed the driver's seat to try and install a powered sub underneath it. I'm pretty sure they figured out how to remove the front seat on their own from the pictures in another thread.
    FYI, both front seats are secured by four bolts with T50 heads, and they're torqued to 37Nm/27ftlb. The reassembly instructions do not call for locktite, but they are supposed to be torqued using a cross pattern.
