How to remove HV battery vent cover?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paprius4030, Oct 16, 2017.
  1. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Hi All, I want to remove the cover for the HV battery vent cover in the back seat. Can somebody please tell me how to remove it. The dealer did it the last time I wanted the vent checked and cleaned and I'm afraid too pull it too hard and break something. Do you just yank on it real good to pop it off or is there some trick. It doesn't seem to want to come off. Thanks for your help.
  2. ChapmanF
    15,666
    Remove the bolt at the bottom, then lift.
    -Chap
  3. Mendel Leisk
    38,736
    The bolt is accessible between the seat bottom and back. You'll need about a 9" extension on a ratchet wrench (say 6" plus 3"). A light on a headstrap is handy too. It's 12 mm socket size, IIRC.
    Once that bolt is out (don't drop it), kind of release the seat back and tilting it forward a bit seems to help, when pulling up and off the seatback portion with the grill.
    You'll also need to pry off the hatch floor above the battery, and peel back the carpet off some velcro strips. There's one at least more bolt in there somewhere, and a number of XMass tree style plastic fasteners and clips.
    Just keep pulling the various conduits off, it's not too hard. The fan itself can be cleaned without complete removal, with Q-Tips or a small brush, then maybe some compressed air. One of those dust wands is good for cleaning the various ducts.
    (I guess that's the verbose answer, lol.)
    Raytheeagle and mjoo like this.
  4. paprius4030
    2,077
    296
    York,Pa.
    Thanks a lot! I'm glad I asked and didn't just yank on the cover.
  5. Mendel Leisk
    38,736
    One thing you will need to yank on (carefully) is the rear hatch floor over the battery. It has stubborn plastic fasteners. I used a pry tool (or three) and eventually popped them out, without any breakage. At reinstall I opted to leave them all off, there was still plenty of tabs to keep that area secure.
  6. Siward
    Siward Active Member
    296
    124
    Toronto
    I was watching this video yesterday. It shows how to remove the entire vent column at around 7:10
  7. Mendel Leisk
    38,736
    NutzAboutBolts likes this.
  8. paprius4030
    2,077
    296
    York,Pa.
    Thanks All, Good videos
