How to remove rear seat on 2010-14 prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bear15, Mar 1, 2012.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    2012 Prius REAR SEAT REMOVAL and REINSTALL
    Removal-
    Slide hand under the front of the rear seat approx. 1 foot in from the end. Using both hands, YANK up hard until the side comes up. Do the same for the other side. For best results, use 2 people: one on each side of the front edge of the seat bottom.
    Reinstalling-
    One item many people are having problems with is getting the front loop hooks to fasten when reinstalling the rear seat bottom. We had the same issue.
    Try: Tilt the rear seat backs forward approx 45 degrees so you can get your hand down to the rear loop hook. While facing the rear of the car, pull up on the rear loop hook and kneel down (using much pressure) on the front while gently moving from side to side. After a moment or so, you should hear a click indicating that the seat is installed. Then go to the other side and do the same. If this does not work, check to see if the plastic pins in the plastic receptacles are broken and/or try the below.
    Or
    I saw that the two front metal bar loops were supposed to snap back into the plastic receptacles and I used a plastic trim removal tool to pop the receptacles out of the metal bracket and then I popped them onto the seat loops with a rubber mallet. (This is with the seat bottom out and upside down). Then the seat snapped right back down no problem.
    Note: If replacement receptacles are need, they only cost approx. $5.00 each.
  2. harp3333
    harp3333 New Member
    I just used the OR method above...couldn't get loop hooks to lock in receptacles after installing rear seat cover...near impossible to apply enough pressure to get them to lock. Went by local Toyota dealership and bought 2 white plastic receptacles the hooks snap into ($3.75 each) ...removed old receptacles from car floor (they are difficult to get out and chances are you will damage them getting them out), used rubber mallet to connect new receptacles to seat bottom hooks. The new receptacles went into the holes in the car floor very easily and snapped in place...dont forget to make sure the hooks in the back of the seat are hooked properly and the seatbelts are on top of the seat! Thanks bear15 for a great and cheap solution!
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Hmm, I had no problem at all when I did this a few months ago. If they won't snap back -sit on the seat and bounce-! DO be careful to control the belts. Otherwise you could be pulling it off again to find them. ;)
  4. harp3333
    harp3333 New Member
    It worked fine the first time I removed the seats to make sure it could be done. The hooks clicked right back into the receptacles. Two weeks later after putting seat covers on no amount of bouncing would work...not sure what the prob was but had to resort to the receptacle method above.
  5. bwilson4web
    15,513
    Do you have photos with the rear seat removed?
    I am looking for a place to stow a 1.5/3.0 kW inverter. The area behind the battery is pretty well filled or I have to do something creative about the rear, under floor area and spare tire. But after seeing a photo of the 'Prius c' area under the rear seat where the 12V battery is stored, I'm wondering if the ZVW30 might have some 'stow' space there.
    The other thing I'm thinking about is making a split, rear seat to ease transportation of my wife's battery powered, chair. Right now, I can put it in but it is tight. But if the seat half behind the driver is removed, we'll gain a lot of 'cargo' volume.
    Thanks,
  6. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Does any one know how to remove rear seat on third generation prius to install seat covers. I have completed the front seat installation that was easy. I've read previous posts and followed the instructions but still unable to remove the rear seats:mad:
    Alan Ellis likes this.
  7. Alan Ellis
    Alan Ellis New Member
    22
    I need to remove the rear seats to for leather seat installation cant find any directions on how to take the rear seats out?
    I wish I could see the Youtube on this so I can visualize this better.
  8. Seanzky
    Seanzky Member
    150
    28
    NY
    I'm probably going to need these instructions, too. I'm interested in some PVC or leather covers but I have no clue how to remove the back seats.
    SGH-T999 ?
  9. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Clazzio leather seat covers comes with instruction on how to remove the rear seats.
  10. Alan Ellis
    22
    Went to the Toyota Dealership and got help on the removal of seats Push in with your knee on the left side and lift up hard then go to right side and do the same thing. You can follow direction on this my directions straight from the dealership is way better would hate that you screwed something up on this.
    Geo Dude and AmericasDawn like this.
  11. AmericasDawn
    AmericasDawn Junior Member
    St. Louis, MO
    Thanks for the dealer-approved instructions. I got the back seat out on my first try. Luckily, I was even able to re-install the seat (with my new Clazzio's) without much of a hassle. Thank you again for sharing (y)
  12. Alan Ellis
    22
    Your welcome!
  13. RIKER
    RIKER Junior Member
    Indiana
    I'm installing a full set of Coverking Spacer Mesh seat covers from AutoAnything into my 2013 Prius Two and ran into the roadblock of how to get the straps underneath the rear seat's bottom cushion. There's not enough room to pass the straps through, so the seat base needs to be removed. I didn't find any diagrams online for how to remove/install the seat, but even better I found a great 'how to' that starts at the 9:30 mark in this video. PriusChat wouldn't let me include the link, so I listed the title on YouTube for people to search for the video instead. This is my first post on PriusChat, and I'm just trying to provide some assistance to other Prius owners.
    The title of the YouTube video is...
    "How to install Clazzio car seat cover (perfect guide)"
    #13 RIKER, May 31, 2015
    Geo Dude and Bobby T like this.
  14. Bobby T
    Bobby T Junior Member
    Chicago
    Thanks for this video. Am trying to install and different seat cover name brand.
    SanDiegoClint likes this.
  15. Eric Hehs
    Eric Hehs Junior Member
    Photos show location of the plastic seat receptacles for the rear seats. I used a ball joint separator to pry up the seat. Insert it as a pry bar at the receptacle on each side to get the seat out. I did one side at a time. My rear seat took a LOT of effort before finally popping out. Could not pop it out of the receptacles by simply pulling up the seat. Good luck.
    Adric and orenji like this.
