How to remove steering wheel airbag cable...
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by EV-Nut, Feb 9, 2013.
  1. EV-Nut
    EV-Nut Junior Member
    Hello,
    Does anyone know how to remove the steering wheel airbag cable (yellow). I can disconnect the airbag but I can't disconnect the other end... as per the attached pic (from another member of this forum).
    Many thanks in advance...
    C
  2. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I'm curious, now that you removed the air bag, where are the plugs for the steering wheel radio, phone & temp bottons??
    I'm asking this cause I will change mine with the voice command button.
  3. EV-Nut
    The plugs are the ones you see beside the airbag/yellow cable. Those are easy to remove.
  4. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I'm lost to as why you are doing this?
  5. EV-Nut
    Blown airbag... burnt & melted wires... I wish to reconstruct as the factory set-up, but unfortunately I was not able to source the piece of cable (yet).
  6. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Oh ok did you get into an accident?? What happened?
  7. MWD
    MWD New Member
    I think the yellow wires go to the clock spring by the way I have anew steering wheel if you need one and I think there is I new clock spring on ebay
  8. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Can anyone confirm if the regular prius steering wheel is the same as the C? I have also seen vendors claim that the Prius / Prius C / Prius V all share the same steering wheel.
  9. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    they're the same.
