How to remove the Toyota emblem from the rear, a question ?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by I'mJp, Apr 17, 2016.
  1. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I've tried various strings, they get eaten savagely.
    Must be some sort of thread in there.
    Anybody know what needs to be disassembled to remove the emblem ?
    I plan on replacing it with an emblem of my choice.
    jp
  2. SpiniSpipi
    SpiniSpipi Junior Member
    28
    36
    Los Angeles
    Three Touring
    I assume it needs to be pried out, if the design is consistent with the last gens, same for the emblem in the front. However I am waiting for a confirmed answer too. +1
  3. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    Oversplode likes this.
  4. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I would not recommend removing the badge.
    It required using a string heavy enough to cut thru one of the plastic pins on the badge.
    Once that went, and I got 3/4 through, I was able to pull the badge off.
    Your replacement badge had better fill the space !!!
    The square area around the hole in the center is unpainted plastic.
    #4 I'mJp, Apr 18, 2016
  5. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    If it's like the Gen III emblem, it is not just stuck on with adhesive, there are holes in the bodywork where its attached.
  6. randomwalk101
    randomwalk101 DYI'er
    532
    269
    texas
    That square hole is where the sensor for the radar cruise control sits (if equipped).
  7. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    The radar cruise goes in the front of the car.
    I don't think that I need to cruise in the reverse ! That would be scary.
  8. randomwalk101
    532
    269
    texas
    Opppss..sorry my bad..I thought I'm looking at the emblem from the front :)
