How to remove undercarriage retainer clip?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Peakbagger, Mar 18, 2018.
  1. Peakbagger
    Peakbagger New Member
    Washington State
    I have a couple of plastic panels that are hanging somewhat loose under my Prius. It looks like one or two of the clips are broken, but a couple of them still have the male clip (p/n: 90467-17027-C0) inserted. How do I remove these? Can't figure it out!
    Thanks!
    #1 Peakbagger, Mar 18, 2018
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,691
    Bay Area
    Check our YouTube channel, we have a video showing it.
  3. Mendel Leisk
    40,580
    All the underpanel clips, you pry up the center disk, that lets the jaws relax inward, and then it'll pull out. if they're gritty it will be tricky. Go slow, and use as wide a pry tool as possible. Or two-sided if it's really fighting. You can also use the two sided tool under the whole fastener head. Here's my tools, they're all handy at one time or another. The paint can opener I use the most, because of the right angle tip. The slim-blade screw driver is sometimes best. And sometimes, especially if you get them started but they're fighting, the red handled tool is good, due to being double sided it's gentler if the fastener is stuck/jammed.
    Also, ALWAYS wash them out in hot/soapy water before reinstall, and work the mechanism a bit while washing.
    #3 Mendel Leisk, Mar 18, 2018
    Peakbagger likes this.
  4. Peakbagger
    Washington State
    Thanks - is that the "Toyota Prius Transmission Drain And Refill" video? So you just pry them loose with a flat head?
    NutzAboutBolts likes this.
  5. Peakbagger
    Washington State
    Thanks Mendel. It just so happens we have a paint can opener handy! I'll give it a try.
    It looks like on one of the clips, only a small part of the center disk is left. How would you handle that?
  6. NutzAboutBolts
    1,601
    1,691
    Bay Area
    Either pull that clip out or push the center part in to undo it, and that looks like the wrong clip they installed.
  7. Mendel Leisk
    40,580
    I maybe misspoke lol, saying they're all the same. The engine underpanel fasteners arr, apart from having minor size variations, but going back into the mid-length panels, there are some different ones: large diameter, that hold the panel a bit away from the car body. I haven't messed with those.
    There's also a wack of different styles of fasteners on the body-coloured plastic rocker panel. Again, something I haven't touched. I've noticed a few of the latter disintegrating though.
    Can you clarify where that pic is?
  8. Mendel Leisk
    40,580
    Maybe location #1?
  9. Peakbagger
    Washington State
    Mendel, you're close - I've been able to identify broken ones at these two locations:
    Based on that, are those the wrong clips as NutzandBoltz mentioned? The replacement clips are slightly different but I think with the same idea, functioning as standoffs.
  10. Mendel Leisk
    40,580
    The full panels might be #'s 24 and 25 here:
    Floor & Rails for 2012 Toyota Prius | Toyota Parts
    Not too long back, someone else was looking for those fasteners, and I can't recall if it was resolved, if it was possible to just get the fasteners, or you had to spring for the full panel.
    Dealership parts department might be more able to determine that.
  11. Peakbagger
    Washington State
    Figured it out. Just had to unscrew it from the bolt, LOL. Replacement works like a charm. The other clip, which holds the two overlapping panels to the car is different, though. Looks like another trip to the parts department!
  12. KCSwiss
    KCSwiss Junior Member
    Don't know if this appropriate thread but here goes. I paid for life-time oil change from Lithia Toyota and have been very happy for the 125K miles UNITL I noticed a portion of the under cover hanging down and appeared to have been damaged from scraping the road. I looked underneath and noticed the square portion (normally moved while still attached to access filter and drain bolt) was missing. I also determined there were several broken clips. I went to the dealership that does my service and questioned one of the service writers if they replaced the broken clips if broken. He said no, and really, I didn't even need the undercover. I was not amused; especially as I broke a couple of them getting the whole undercover off to reattach the loose piece and paid a buck a piece for replacements. My concerns are if the undercover serves no useful purpose, why is it there? If, as I understand it, they are "missing" on most cars, did they just fall off while going down the road, tearing up the undercarriage and flying up and hitting another car? If they are that incompetent (can't use the correct tool or replace what they broke), why am I letting them do ANYTHING to my car? I have spoken to the sales guy who kind of hinted the lack of concern on service part but will be going for replacement of the items they broke and from now on, I'll bring some extra clips and inspect it before I leave.
    j12piprius likes this.
  13. Grit
    Grit Senior Member
    6,452
    4,186
    Wilkes Land
    That's why prepaid oil changes are garbage. They're not liable for any damages (unless the word small claim court is used) if they "forget" to tighten drain bolt, put in the paper cartridge and not put in the correct or use the lowest quality engine oil. They aren't obligated to replace any broken missing pins either, it's funny to see many cars drive pass with drain oil flaps scrubbing the ground.
  14. Mendel Leisk
    40,580
    Yeah, take a fragile plastic underpanel with finicky fasteners, and a local flap at the oil pan, with a "hinge" made of thin/brittle plastic, then add rushed, under the gun mechanics, and you have what you have.
    The best way to avoid this in future: DIY your oil changes if at all possible. Repair/replace fasteners and/or the whole panel, as needed. Remove the fasteners carefully (per discussion above), and before reinstall wash the grit out of them with soapy water, working the mechaism a bit. Also put a drop of oil on the threads of the bolts, and hand-tighten them not too agressively.
    The attachment has parts numbers.
    (FWIW, I've done about 15 oil changes, taking the full panel off each time, and had it off at least another 5~6 times. I've had one fastener that missing one tooth. And one of the bolts fell off, my bad: I left them loose to assist in aligning all the holes. And then forgot to tighten...)
    #14 Mendel Leisk, Jun 17, 2018
  15. EdgarTX
    EdgarTX New Member
    I am having the same issue, do you have the part number for those clips? One of the clips its gone and the other one its broken but still holds. Thank you
  16. Mendel Leisk
    40,580
  17. EdgarTX
    EdgarTX New Member
    Thank you for your help, yes that is it, I will try to find it online.
