How to remove undercarriage "screw" 2011 Gen 3
Discussion in 'Gen 3 Prius Main Forum' started by spicegirl, Oct 13, 2019.
  1. spicegirl
    spicegirl Prius shopper
    TN
    Hello,
    Can anyone tell me how to remove the plastic undercarriage cover? There's gravel stuck in the cover and I can't get it out (tried to "sweep" it and vacuum it).
    Underneath the car, at the right front (passenger) door, there's a plastic undercarriage cover. It's held in by what look like plastic screws that have a wide "top" (sorry, not very technical language). It's not a body clip, it has what looks like (large) Philip's head slots and a little "lip" that you can use to unscrew them. I tried unscrewing by hand, but it didn't do anything. I don't want to force it or break them.
    Thanks!
    SG
  2. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    The center part pulls out. Use a flat blade screw driver. I may brake, most of them do sooner or later.
  3. Mendel Leisk
    38,702
    I'm usually pretty "up" on checking those underpanels, remove a lot of them, just to see how it's done, and/or to check for mud/dirt accumulation. But that side piece stymied me. I see on ours one or two of the "fasteners" have actually rattled loose and departed. There's several different styles of fasteners too? A real committee design for sure. Good luck, hope you get it figured out. (y)
    Attached is a relevant Repair Manual excerpt, not sure how helpful.
  4. Leadfoot J. McCoalroller
    7,157
    6,711
    Pennsylvania
    2018 Prius c
    Dirt falls into the backside of these and they jam up. It makes it inevitable that you’ll break a couple. You can get cheap generic replacements from most local autoparts stores. They may not have the same style heads but virtually all 8mm pop fasteners will work for you.
  5. Mendel Leisk
    38,702
    Whenever you have plastic fasteners out, wash them in a pail/bowl of hot soapy water, and work the mechanism a bit too. It helps some.
    For prying plastic fasteners out, I find a paint can opener like this:
    to be most useful. I'll sometimes also use a small flat blade screwdriver, alone or in concert with the above. If the fastener head is up but the dang thing still won't come out, one of these:
    the conventional automotive fastener pry tool, can sometimes help: wedge it under the fastener collar and gently lever up.
    #5 Mendel Leisk, Oct 13, 2019
  6. BZzap!
    BZzap! Senior Member
    1,607
    877
    I find that a pocket screw drive works best to remove the compression tab from these types of fasteners. D371F1B4-BC66-4911-BC50-8CE90DB4A8C4.png
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,160
    2,208
    Taylors, SC
    If the heads are not already stripped, push the tip of a blade screwdriver on the outer ring or "washer" of the fastener to hold it in place. The center should screw out in the anti-clockwise direction. Not holding the "washer" will cause the entire fastener assembly to spin and stay in place.
    If the center is stripped, you can drill them out with a 1/4 inch drill bit and pry off the remaining "washer" part with a screw driver.
    Toyota uses 7mm Nylon 6-6 push rivets. More common 8mm ones used on many other import cars will not work, so make sure you get genuine Toyota 7mm ones or their generic equivalents.
  8. Leadfoot J. McCoalroller
    7,157
    6,711
    Pennsylvania
    2018 Prius c
    Thanks! apparently I’m buying 7mm fasteners out of an 8mm bin.
    Georgina Rudkus and bettergolf like this.
  9. Mendel Leisk
    38,702
    That's one thing to be cautious of: bin-stored fasteners in hardware stores get badly mixed. To be fair: it's easy to do, lol.
    #9 Mendel Leisk, Oct 13, 2019
  10. spicegirl
    TN
    Just to be clear, here's a pic. Are we talking about this type of fastener?
    Thank you!
  11. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    More along the lines of this:
  12. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    o_O
  13. Elektroingenieur
    2,515
    3,258
    Three Touring
    No, those are different than the ones kindly described in earlier postings. Here’s a page in Japanese with a good photo showing how those clips work and advice on removing them. If you try to loosen one with a screwdriver, the natural tendency to push in on the fastener will just press it back onto the bolt. Instead, turn the fastener gently while pulling the cover away from the car.
    If you break one, though, it can be replaced: parts catalog Figure 51-02, Suspension Crossmember & Under Cover, says the list price for a clip, part number 90467-17025-C0, is $2.61.
  14. Mendel Leisk
    38,702
    I was thinking of the rocker panel, thanks for clearing it up.
  15. spicegirl
    TN
    Thanks so much @Elektroingenieur
    I used translate to try to figure out what to do. I'll play with it and see how it goes. Appreciate the parts catalog info as well!
    Elektroingenieur likes this.
  16. spicegirl
    TN
    Sorry @Mendel Leisk and all that I didn't include a pic in the first place. Lesson learned. ;)
  17. spicegirl
    TN
    Hi everyone,
    I got it! I added an image with notes on how I got the clip to detach (the clip stays on the the undercarriage tray once you unscrew it, then just pops back on). It wasn't difficult once I knew what was going on.
    Thank you all so much.
    SG
