How to Replace Gen II Prius Spark Plugs and PCV Valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zedhomme, Oct 14, 2013.
  1. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    I've seen some posts where people have removed the wiper arm assemblies and the cowl to replace the spark plugs and Vent Valve subassembly (PCV). This is not necessary, if you have or buy a tool. It's a 19mm reversible ratcheting combination wrench. I consulted the repair manual and replace my plugs and PCV with much less trouble. I'm attaching an Adobe pdf file of the process.
    Hope it helps someone save some money and get ready to enjoy the NEXT 120,000 miles.
    Here is the text version too. Costs are what I paid for OEM replacements at Toyota Dealer.
    PARTS: (4) 90080-91184, SK16R11 IRIDIUM Spark Plugs @9.70 =$38.80
    (1) 12204-21011 Valve Sub-assembly (PCV Valve) @ $9.12
    (1 packet) Anti-seize compound for plug threads. Buy a foil packet at auto parts store.
    Tools: Torque Wrench, Ratchet, 10mm socket, socket extension, 19mm reversible ratcheting Combination Wrench Cost $22 at Sears, PRICELESS to replace PCV Valve. With it NO NEED to remove wipers and cowl.
    STEPS:
    1) Remove Engine Room Relay Block (10mm socket), hang out of way w/bungie cord
    2) Disconnect Electrical Connector of MAF Meter from Air Cleaner
    3) Remove Air Cleaner Assembly, hose and 2 bolts (10mm socket) Cover Throttle Body Throat
    4) Disconnect Wire Harness (4 - 10mm bolts) Carefully move out of way.
    5) Disconnect fuel injector connector and Ignition Coils (10mm bolts). Check for water damage, cracks on coils. Prius has had issues with water running down the cowl and sitting on ignition coils causing damage and rough running.
    6) Remove Spark Plugs (16mm plug socket, rubber lined)
    7) Install new plugs, use anti-seize compound on threads. Can buy a packet at auto parts for about $1. Start threading new plugs by hand. Then, torque to 13 ft lbs.
    BONUS!! --Replace PCV Valve while these components are off. 19mm reversible ratcheting combination wrench (Tight fit)
    1) Disconnect Vent hose (Clamp)
    2) Unscrew Vent Valve, Replace, torque to 20 ft. lb. Really can't get a torque wrench in without removing brake master cylinder, but don't overtighten.
    3) Reattach vent hose.
    4) Reinstall components. Torque values are in pdf for most bolts.
  2. northcoaster
    northcoaster Junior Member
    32
    northcoast
    Thank you so much! does anybody have a video of at least part of this?
  3. N.J.PRIUS
    N.J.PRIUS Member
    140
    50
    Fort Lee, NJ
    2013 Prius Plug-in
    Thank-you for posting this! I am at 111,000 miles and will be needing to do both of these procedures soon. A video would be great! Thanks again for posting this.
    My local Toyota dealer just quoted me $108.00 for spark plug replacement.
  4. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    I didn't have time this weekend. I'll try and come up with one next weekend. It may be slightly abbreviated. Don't really want to pull all the plugs out again, but will try to do the majority of it.
  5. Chris Dragon
    Chris Dragon Junior Member
    22
    Hi Zedhomme,
    Thanks for the guide!
    When you say "USE SOCKET WITH RUBBER-LINED 16MM PLUG SOCKET TO REMOVE AND INSTALL PLUGS TO
    AVOID BREAKING CERAMIC.", do you mean just use a normal plug socket adapter and add rubber? Like a bike tire tube, maybe? You should include those bits in your list of tools required.
  6. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Chris, the rubber lining (washer) is included as a standard part of most spark plug sockets. The main purpose of this rubber insert is to hold the spark plug firmly and allow it to be easily inserted or removed (from the spark plug well).
    BTW. A 5/8" spark plug socket will fit just as well.
  7. Patrick Wong
    18,210
    6,511
    A further purpose of the insert is that it keeps the deep socket properly aligned with the spark plug to avoid damage to the plug. If you use a 5/8" or 16 mm deep socket without a rubber insert, it is easy to place the socket so that the plug is not exactly coaxial within, which will result in stress on the ceramic tail and some likelihood that the tail will break off.
  8. Chris Dragon
    22
    Ah, cool. I was confused because the plug sockets I was looking at on Amazon never mentioned rubber, but maybe it's just assumed, or not all have it. This one does mention rubber. This one says it has a "rubber retaining ring" while this one says "rubber insert". I wonder if they're the same thing? "Rubber insert" sounds more promising.
    Okinawa likes this.
  9. neez
    neez Member
    194
    37
    You aren't supposed to use anti-seize with plated plugs, like iridium. It's not necessary because the aluminum doesn't contact the steel, and the anti-seize acts as a lubricant allowing for people to over-torque the plugs. Generally all cars use iridium today, and you won't see any anti-seize on the plugs from the factory.
  10. MtBiker
    MtBiker Junior Member
    26
    I'm considering buying this X-Beam design 19mm wrench for this job due to it's flat surface area in which to apply more pressure. I'm concerned though that this design might interfere with something during the plug change. Is there plenty of room for the X-Beam wrench or should I stick with the regular design? Thanks.
  11. Patrick Wong
    18,210
    6,511
    The purpose of a 19 mm wrench is to remove the PCV valve. This adds no value regarding the spark plug change.
  12. MtBiker
    26
    I know that. If you look at the two different wrench designs, the x-beam design has a wider shank profile when turning than the standard design and could interfere if there isn't enough room for it. I want to know if there's enough room, in whatever turning angle is available, to use the x-beam design to remove the PCV valve.
  13. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    There is very little room to get a wrench on the end of the PCV and also not much room to turn it when removing the PCV valve unless you remove the master cylinder. That's why I opted for the ratcheting 19mm. At least you can get each small amount of turn much more quickly.
  14. DarkPri503
    DarkPri503 Junior Member
    68
    Salem
    Thank you for the write up guys. Got my plugs done in under an hour taking my sweet time :) I wasn't prepared for how dirty the throttle body was and will go back in for a go a cleaning it up. I opted not to change the PCV this go around, as this Prius hasn't shown any signs or symptoms of ailment yet! :)
    My next project will be the coolant and possibly 12v, though I'll have to check its myToyota service record as it was babied and lots of maintenance was done prior to needing it.
    Here is a shot if the plugs being pulled at 124k. They look incredible for that many miles, mostly in 100° AZ weather!
  15. usnavystgc
    3,159
    990
    Tucson, AZ
    As usual, they look perfect still.
  16. JC91006
    16,778
    8,575
    Those old plugs look so good, I'm tempted to ask you to send them to me............
    DarkPri503 likes this.
  17. DarkPri503
    68
    Salem
    Ha!
    I have a concern though. After driving it the past couple days, it doesn't seem as zippy :/
    I checked the gap and it looked okay, though I might have been look at it wrong (between .040-.050 I believe, using the old coin measurer) and the igniter coil didn't really click when pushed in. I couldn't find my torque wrench so I hand tightened. I'm wondering if any if these concerns could be causing the perceived loss of power?
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    Hand tight????? That's not near tight enough. You need to find a torque wrench. I think the gap is supposed to be 1.0 mm (check on that though).
  19. Mendel Leisk
    41,582
    ^ Just a couple of thoughts:
    A lot of the high end plugs warn against adjusting gap. They're set at time of manufacture, and are not adjustable. Check on website what your's say.
    This is one time I would have hunted high and low till I found the torque wrench. They're typically pretty low torque values specd. 15~20 foot pounds. A smaller torque wrench with that range is best.
  20. DarkPri503
    68
    Salem
    Sorry, hand tighten plus 1/4-1/2 turn more for snug fit.
  21. JC91006
    16,778
    8,575
    Hand tightening doesn't always seat the plug properly. Sometimes it's still not tight even if you give it an additional 1/4 or 1/2 turn. Did any of them feel loose after the 1/2 turn? Like you can give it another 1/2 turn without effort? When I don't have a torque wrench handy, I normally seat it using a wrench and then tighten it an additional 1/4 turn.
