How to Replace My Fog light bulbs?
Discussion in 'Gen 2 Prius Technical Discussion' started by N3FOL, Dec 8, 2009.
  1. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I'd like to replace my light bulbs in the fogs. Looks like I will need to remove the grill? Where are the bolts hidden (behind?)? Please advise.
    KLD_Prius_PI_Synergy likes this.
  2. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I think I hit a big bump on this. All I need to know is (not detailed), what is the easy way to get to the fog lamp bulbs to replace them. I am pretty good in following directions too. :D
  3. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    ok, since nobody responded to my inquiry...I went ahead and worked on this task yesterday. I was able to replace my stock fog lamps with PIAA Super White 9006 51W bulbs and the result is just remarkable. The money spent is well worth it.
    I was able to fit my small hands underneath the plastic cover with only removing one plastic tab on each side. A twist to the left removed the stock lamps...it was so easy ... a caveman can really figure this out. :)
  4. Oddest_raindrop
    Oddest_raindrop New Member
    75
    wisconsin
    I was thinking about changing the fog lamps out my self but really wondering if it was going to be worth it. Now I just wonder if my big hands will be able to do it.
  5. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    thanks for the info. i too want to change the foglamps.
  6. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    From the service manual, the official way to do it is to remove the front bumper cover and lower grill. Ouch.
  7. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    Sorry I couldn't offer info on how to change them. I had mine changed by a shop at the same time they were doing something else, and I didn't watch how they accessed them. My new bulbs are PIAA Xtreme While Plus Bulbs - 9006. The package says they change output to 115W.
    Given the good results you achieved, can you tell me how you have the fog lamps aimed vs how the headlights are aimed? Also, do you know whether the fog lamps can also be adjusted more or less to the side of the Prius, or, are they just adjustable up and down.
    When I got my Prius, the foglamps were aimed so low I couldn't see any change in brightness when I turned them on. They were pointed to closely towards the ground I couldn't see their light band over the hood etc. I had the dealer raise their aim, but they didn't move it very far up ... I can see some difference now, but it's hardly worth having. I am thinking of pushing their aim to equal that of the low beams.
    My other car is a Sebring, also with fog lamps. When you turn them on, you really get results. The area in front of you lights up considerably more, and there is considerable extra light to both sides as well (good for seeing deer before you otherwise hit them).
    Thanks for any help offered,
    Rick
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    2 people like this.
  9. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Please remember that for every action, there is also an equal and opposite reaction.
    Improving your view by aiming your fogs higher, thus causing increased light spill, will greatly impede the view for all drivers that face your car.
  10. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    If you have big hands, you may have to remove another plastic snap underneathe. You will have to jack up the front and don't forget to place a jack stand for safety. Once you get underneathe, you will see what I mean. ;)
  11. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Really nothing to it. Take your time and be very careful not to touch the bulbs with your bare hands. At the time of my installation, I wore latex rubber gloves. Good Luck. Let us know how it turns out.
  12. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Hello Rick. When I installed my PIAA fog lamps, I left the housing as it is. I really did not see any adjustment to the fog lamp housing and I seriously doubt your dealer whether or not they really adjusted how your fog lamps are aimed. My HID headlights - I did not touch and did not do any adjustment to them. If your car have HIDs, the lights illuminate the corners very well almost down to the ditch area where Bambi may be standing. ;)
    On a positive note, my fog lights does look a lot brighter than the OEMs. The more bright lights in front, the better. :cool:
  13. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I am scratching my head on that...Why? I simply removed the plastic snaps close to the foglamps and they are very accessible.
  14. Belrick
    Belrick New Member
    Hi,thanks for the info on changing the fog lamps.
    I just did it and it took maybe 30 min?
    I unscrewed the one nut 6in below the lamp holding the plastic bottom on. {actually did two but not sure if the second was necessary}.
    When you look in there is an electrical connector just pull that off and twist the holder to the left holder its a gray plastic piece.
    I bought new bulbs but when I looked from under the car the connector was not attached so not sure how you get it off. I changed the bulb anyway and reconnected the cable push on until it clicks, and the light came on.
    I have large hands and managed fine and I never jacked the car up either though its a hard squeeze to get your head under and see upwards. This is easy, the electrical connection comes off, then the whole part holder and bulb turns.
    Thanks guys this forum is indispensable.
    Bill
  15. HappyHybrid
    HappyHybrid Junior Member
    Raleigh, NC
    I've got one fog light that's out in my 2007 Prius, and was all set to change it myself, until I read in my manual that that was the ONE bulb that I shouldn't try to do myself. They give you detailed instructions for the headlights and even the license plate light, but specifically say to NOT try to do the fog lights yourself.
    Imagine my surprise to read that it IS a DIY kind of thing. Will continue to read up on it, maybe I'll give it a go after all. Would rather NOT pay someone to do something I can do myself.
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The foglight bulbs are simple to replace once you move the plastic underbody panels. It's held on by screws on the bottom of the bumper cover. It took me about 15 min to do it the first time.
  17. HappyHybrid
    Raleigh, NC
    Why - other than the obvious Almighty Dollar :rolleyes: - do they tell you that the other lights are okay but specifically NOT to replace your fog lights on your own, then? I was all set to jump in and attempt it myself, used to change lights on my old car all the time, but when I pulled out the manual to see how to do it, they made it sound like the world would end if I tried to do it myself.
    Sounds like I'm making another run to the auto parts store this week and give it a go over the holiday weekend next weekend.
  18. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Maybe they are worried about heat? A standard wattage bulb should be fine. Some of the higher wattage bulbs may run hotter and cause the reflective surface to eventually peel. I ran high wattage PIAA bulbs for awhile and didn't have any issues but removed them later since output didn't increase appreciably.
