How to replace the plastic trunk "handle" that houses the rear hatch opener?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2007Gen2, Nov 24, 2014.
  1. 2007Gen2
    2007Gen2 Junior Member
    California, California
    Can someone with a factory repair manual explain how I go about changing the rear plastic piece that houses the rear trunk opener? Not sure the name of it? It's the wide plastic piece affixed to the rear hatch...it has the toyota symbol on it. My girl broke it....one of the internal plastic mounting brackets broke. I'm figuring that I have to go in from inside the car, but I was hoping I could get a rundown on the procedure before attempting it. I drilled a hole and put a sheet metal screw thru it into the metal of the rear hatch so its now hanging there and flopping around. Thanks in advance folks.
    49,469
    patrick wong has an instructional thread here.
  3. Patrick Wong
    18,200
    6,474
    49,469
    than you!:)
