How to replace the whole hatch?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by QsterCt, Feb 14, 2022.
  1. QsterCt
    QsterCt New Member
    Connecticut
    Hi everyone,
    My daughter got into a minor fender bender at low speeds, but the spoiler and back glass are broken. I can get a used replacement hatch for $300, but I can’t find any videos on replacing it. It seems like it would just be disconnect the hinges and lift sports, disconnect the electronics (not sure how that is) and reconnect everything.
    Could anyone shed any light on how to replace the hatch and if that’s too hard? I’m pretty handy, and we previously replaced tail lights and other stuff, but that was with YouTube help.
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    Yea, that's about it. Suspect the reason for no info on it is because it's an easy thing to do.
  3. ChapmanF
    15,617
    Or that sort of magical combination of easy-enough and rare-enough that nobody has thought to make a video for it.
    You should find useful information in the repair manual (more info). It will just be text and drawings, no video, but should help you get the job done.
    Probably the most interesting bits will be where the wire harness connectors are that you need to disconnect, under the headliner or under the hatch trim, and the right ways to get the trim out of the way ... same for the rear washer fluid hose. And how to adjust the latch and hinges with the new one so it's all lined up right.
    Be prepared for the weight of the hatch ... once you undo the gas struts that support it, it can be heavier than you think.
  4. PriusCamper
    11,105
    4,518
    I've always wanted to set up some rigging in my carport so it's easier to unbolt hatch and detail the paint around the hinges where the hatch attaches. It's such a pain trying to clean, polish and wax that part of the car. Hopefully will do that soon.
  5. QsterCt
    QsterCt New Member
    Connecticut
    Thanks everyone for the help! We changed it out yesterday, and it was actually pretty easy. Had to take out the top trim to get to the wiring, which plugged in in two spots, and the wiper fluid line. Then outlined the hinges so they went back properly. Then loosened the hinge bolts from under the trim, popped off the support struts and took the hinge bolts off the rest of the way. We popped the hinge bolts up and lifted/slid the hatch off. Did the whole thing in reverse to put the replacement hatch on. It took about three hours.
    I ended up getting the Haynes manual, which was helpful, and now we can use if for other stuff.
    thanks everyone for your help!
  6. bisco
    49,492
    congrats, well done!
    QsterCt likes this.
