How to replace TPMS in Prius Wheels 2007
Discussion in 'Gen 2 Prius Technical Discussion' started by bear15, Apr 13, 2011.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Does anyone know how to replace TPMS in Prius Wheels? We have a 2007 Touring Prius with the 16" wheels.
  2. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    Remove tire from wheel.
    Remove nut on the valve stem on outside of wheel.
    Pull TPMS sensor into the wheel (inside where the tire is).
    Place new "O" ring on new sensor, apply a bit of silicone grease to it, and install, putting the nut back on.
    Take car to Toyota dealer to have the new sensor programmed into the system.
    Many tire shops can do all of the above for you, or any dealer can do it.
    2 people like this.
  3. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Thanks! Ed
