How to replace your Key Fob battery on a 3rd Gen Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dynasty, Apr 29, 2013.
  1. dynasty
    dynasty Member
    153
    26
    northern NJ
    I received the "low key battery" indicator for the past 5 weeks and i was unable to start my car once the battery's voltage dropped low enough to fail, leaving me stranded at work. I had to call my wife to bring the backup key to my place of work so i can drive home. Lesson learned, dont wait very long once you get the low battery warning indicator! I searched on prius chat and did not find a write up or photos on how to replace the battery so i am taking the liberty to post one. this is a simple DIY for anyone. you will need a small flat head screw driver and one CR1632 battery. (note the battery is different on a 2nd GEN!)
    enjoy!
    STEP 1: Remove small door key from fob
    key1.JPG STEP 2: Where key was inserted you will find a small recessed slot, Insert flat head screwdriver and pry open... work your way around the seams until the two cases become halved. key2.JPG
    STEP 3: Split case in half key3.JPG
    STEP 4: on the side with the circuit board, insert screwdriver on the angled corner and pry back.. there are NO tabs but be gentle. Circuit board will come off the black case... it will feel a bit tacky from the rubber padding on the other side. key4.JPG
    STEP 5: flip board and reveal battery
    STEP 6: using small screw driver, pry out battery from this angle as to not break any retaining tabs. The battery is held in place by a cantilever spring. Replace battery and Reassemble!!
      File size:
      620.4 KB
      749
  2. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Good to know. Thank you!
  3. El Dobro
    El Dobro A Member
    6,979
    3,214
    Even with a dead transmitter battery you can get the car to start by placing the transmitter up against the start button until the light illuminates, then hit the button.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    You don't need a flat head screw driver, you can use the key to pry it on the side. It is the same exact size for that hole.
    KylesPrius likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Hmm...
    Seems like a lot of prying, around very fragile tabs, plus the removal and flipping of the entire circuit board, just to change the battery?
    Doesn't strike me as the most user friendly design.
    BobInSEFlorida likes this.
  6. FriarNurgle
    FriarNurgle Member
    138
    53
    Someone should make this is a sticky.
  7. Chaloney
    Chaloney Junior Member
    I think Toyota did. They stuck it in your owners manual. Page 460 for 2013. That way you can keep it in your car so you will always have it when you need it.
    BobInSEFlorida and FriarNurgle like this.
  8. NutzAboutBolts
    1,476
    1,552
    Bay Area
    It's not fragile at all since they made it strong enough to be removed so that you can replace the battery.
  9. The Electric Me
    9,083
    5,798
    Still think it's not very user friendly. Having to use a small screwdriver and actually remove the circuit board and flip it, just to change the battery doesn't seem very well designed. And some of those tabs look pretty fragile to me. Glad it's something that doesn't have to be done very often.
  10. NutzAboutBolts
    1,476
    1,552
    Bay Area
    you don't need a screw driver to pry open anything. The key FOB has everything built in to remove and replace the battery by hand. I've done it before so I know.
    Unlike the Honda key FOB where you need a Philip screw driver, the Prius key FOB is much easier in my opinion. If you need me to make a video of it, I'll make one tomorrow and post it after and show you :)
  11. almypal26
    almypal26 Member
    101
    So Cal
    Just as DYNASTY demonstrated, very simple process. I had my battery changed after 2 low battery warning, didn't want to wait for complete failure. Took it to a local RADIOSHACK and they replaced it in a few minutes. I even had them check the voltage on the old battery, and it was low. I used the key fob for about 3 1/2 years before replacement. cost about $5.
  12. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    2 dollars for 2 on ebay
  13. The Electric Me
    9,083
    5,798
    Sure it's an easy process, when the guy at Radioshack does it for you.
    I'm not saying it's impossible, rocket science or brain surgery. I think I could do it.
    But I am saying, I think Toyota could of designed the entire fob, with something as basic as a battery access panel. That would of made the whole process a lot easier than having to basically disassemble the whole thing, pry fragile tabs and flip the circuit board.
  14. retired4999
    2,652
    625
    Eau Claire, Wi.
    My dealer changed my battery for free, never hurts to ask. :)
  15. Hoosier1
    Hoosier1 Member
    87
    33
    Southwest Indiana
    Based on experience with a Toyota Camry, expect to replace the battery every two years in order to assure reliability. However, I waited on the primary FOB battery to die before replacing it with a new one. Compared to my old BMW FOB, Toyota has made the battery replacement very easy. Also, you should not store the FOB near electronic devices such as mobile phones, as the devices will cause battery drain on your FOB.
    My new Harley has an active security system that requires the use of a FOB near the bike, but no key is required to start the motorcycle. If your FOB is left at home and you ride off, you must use a start procedure using several steps including an owner selected code. Overall, the system appears to be overly complicated. But, I'll take the insurance discount. My Harley dealer said to replace the battery every year. Hopefully, the battery will last at least two years.
  16. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    One of mine started alarming last week, I have had the car for 3 yrs 10 mo. I replaced them both. Bought the batteries at Wal Mart for $5.95 ea.
  17. Granted
    Granted Junior Member
    Raleigh, NC
    Thank you for posting this Dynasty! When my first fob battery died I took it apart to extract the battery and found nothing (because it was obscured by the circuitboard). Talk about a head scratcher. Why would Toyota expect that people would be comfortable with prying off a circuitboard is beyond me. Most are glued/riveted into place and cannot be reassembled if pried (broken!) off. They should have designed it so the battery was just there waiting for you when you opened up the fob - that's what people are used to.
    Yeah, I know, preaching to the choir...
  18. retired4999
    2,652
    625
    Eau Claire, Wi.
    I think maybe they wanted the fob to be as water tight as possible one less opening to leak around. Notice the thin water tight gasket in the fob. A friend of mine has put the fob thru the wash cycle twice now, no problems. Just a nutty guess! :)
  19. Mendel Leisk
    38,726
    When I did ours I first tried the tip of the embedded key, and while was the right width, something didn't feel "right", it just didn't have enough leverage. Finally settled on a similar, broad bladed screw driver. Width is good, to avoid stressing the case. And as I recall, the clips on the battery are finicky/fragile.
  20. NutzAboutBolts
    1,476
    1,552
    Bay Area
    I'm uploading the video on how to do this as we speak right now, it takes less than 1 minute to do and does not require any special tools. I will post it once its up.
    Here it is!
