How To Reset The Actual Mileage Reminder For The Oil Change Display
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ~FredAverage~, Apr 19, 2021.
  1. ~FredAverage~
    ~FredAverage~ New Member
    West Coast
    Hi all, is it possible to actually change the mileage that dictates when the oil change reminder light comes on on the dash? I’d like to reset mine to come on at 4000 miles. Thank you for any upcoming help offered.
    51,735
    sorry, no. it is set in stone. it is not an oil change reminder, but a maintenance reminder
    Tande likes this.
  3. ~FredAverage~
    West Coast
    OK,Thank you very much
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    AND with most models, it comes on every 5K miles, or a bit before, to indicate it is time to rotate tires.
    That should be close enough for your chosen oil change interval.
  5. Mendel Leisk
    41,161
    The Toyota system is just a dumb miles counter. I would educate yourself about the schedule, and fugedabout the in-dash alert, just ignore it. Canadian Prius don’t have it, food for thought.
  6. ~FredAverage~
    West Coast
    Thanks again all,Yes I understand.
    For years on all my other cars,I’ve always just wrote it under the hood with a felt pen and wiped it off with BrakeKleen ...
    date,mileage and what kind of oil.
    Also, can anyone share with me an easy way to simply change the coolant ,IE; I’m guessing it’s just draining the reservoir & the lower tank on the radiator.?
    I’m hoping it just like “doing” a good old small block Chevy in a ‘65 Nova if you will..... Thanks again.
  7. bisco
    51,735
    the gen 2 screen had a user programmable maintenance reminder, not sure about gen 3.
  8. RRxing
    RRxing Senior Member
    2,541
    1,816
    NEPA
    The "Maintenance Required" screen comes on temporarily when within ~500 miles of the 5000 mile mark. Once it reaches the 5000 mile mark it will stay on until reset. The mileage interval cannot be adjusted. The reset procedure for the 2010 is in the Owner's manual (see attached.)
