How to reset/turnoff the Maintenance Required message when I start up
Discussion in 'Gen 3 Prius Main Forum' started by 348, Jun 17, 2016.
  1. 348
    348 Junior Member
    71
    36
    Central Oregon
    im going to forego the 25,000 maintenance and do the oil changes & such myself from here on out. How do I make the message go away?
    j12piprius likes this.
  2. JC91006
    16,482
    8,400
    1. While the car is running, set your odometer reading to "Trip A". Then turn off car.
    2. While pressing mph/km button on dash, start the car. Keep the mph/km button pressed until you see everything reset (about 8 seconds or so)
    j12piprius and BethPet like this.
  3. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    During Step 2, you don't actually have to start the car. If you leave your foot off the brake and press the Start button twice with the MPH/KM pressed, it will do the same thing. You can release the Start button after the process starts, but keep the MPH/KM button pressed until it completes. The place to look for the process to finish is where the HSI normally is in the center of the top display, i.e., not the touchscreen. It's also where the "Prius" splash screen appears upon power up. A progress bar will appear and move from left to right. If you're not starting the car, just press the Power button at the end to power things down.
    j12piprius, BethPet and 348 like this.
  4. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    p 428 0f the 2010 manual.
    348 likes this.
  5. Nima EB
    Nima EB Junior Member
    Norway
    Hei, I own Prius 2014 model 3. Gen. My car just does not have kph/mph button to reset! I tried TRIP button on steering wheel instead and not resetting. Any suggestions? By the way should you reset Maintenance Data after service though you do not get warning on dash screen?!
  6. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    What is the number of your head unit?
    Should be right bottom side of it - mine is 57034 and doesn’t have service warning.
  7. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    You are too low... follow straight up and you'll see it.
    It hides behind the steering wheel while you're sitting in the drivers seat.
    Johnny Cakes likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Assuming European models had one and it's in the same place, you should find it down low and almost out of sight.
  9. Jason Idleman
    Jason Idleman New Member
    Memphis tn
    What if you can't switch to trip A because the steering wheel buttons don't work?
  10. jerrymildred
    11,511
    14,113
    Tampa, FL
    Then I guess you're stuck till you fix the button. Or you can use Techstream to reset it. Some other ODBII devices might work, too.
    Jason Idleman likes this.
