How to run the A/C overnight?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by plai7778, Mar 12, 2017.
  1. plai7778
    plai7778 Junior Member
    US
    Hi i'm a new Prius owner as of 2017. One of the main reasons i bought the car is its ability to run the a/c without the engine running constantly. I commute for work. I generally spend 2 nights a week out of town. I've been sleeping comfortably in my car while collecting that extra money allotted for hotel accommodations (>$7k/yr). Spring and summer is approaching, my question is for those of you that have experience running the a/c overnight what are some tips and tricks? Do you leave it on air recirculating or air outside? What bar do you leave the fan set on? Do you use the auto climate setting? If you do, please elaborate.
    Please do not post just to tell me not to run the a/c overnight, its a question for those who have camped/sleptovernight in their Prius with the a/c running. I will get a carbon monoxide monitor. Leave windows cracked etc
    adrianmcli, Data Daedalus and bisco like this.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    When I got my v in 2012, I set it on auto and a temp I like, then adjusted the air flow to blow at my feet and chest. I have not adjusted it in over 4 years.
    You should not need a special setting to sleep.
  3. kc410
    kc410 Active Member
    262
    251
    2010 Prius IV
    I've slept in the Prius a few times when camping. I seem to use the same AC settings as when driving...
    Temp to whatever is comfortable
    I usually set to recirculate as humidity is always high in FL.
    I think Auto often has the fan at 2 bars - I may drop it down to one bar to really slow down the fan.
    Snooze away :)
    I find the Prius uses around 1 gal of fuel for a overnight stay in AC - not too bad :)
    ps: never have cracked the windows at night - mosquitoes are supposed to stay outside!
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Ditto above. I use AUTO and let it do its thing. I also use ECO to increase the duration between engine start. The key to sleeping for me is consistency. Everything like the engine starts, I get stirred.
  5. ChapmanF
    15,649
    I seemed to get used to the engine starting and stopping overnight just as easily as I get used to the furnace or A/C starting and stopping at home.
    A CO monitor is smart if you worry about CO. It will give you peace of mind. There's no basis for thinking cracked windows would help. If you use the fresh setting, you're already pulling air in at the front and out at the back. If you use recirc, you're flipping a coin whether that's more likely to let CO in or out. (In fact, it's not even a fair coin; assuming your Prius's body integrity, you wouldn't expect to have much in to be let out.) Anyway, this is all overthinking a risk that your CO monitor will tell you doesn't need to be overthought, as long as you're not parked in a garage or something.
    Happy camping!
    -Chap
    John in Vermont likes this.
  6. Yaesu
    Yaesu Member
    106
    31
    Kentucky
    I have never slept in the Prius or any car with the engine running. However, one thing I would think about would be to park the vehicle with the front facing the wind, to encourage the exhaust to move away from the tailpipe.
    tony_2018 and jerrymildred like this.
  7. kc410
    kc410 Active Member
    262
    251
    2010 Prius IV
    I just found one of my logs from when I was camping & sleeping in the Prius.
    Prius engine would run for ~2 minutes, then turn off for 12-13 minutes.
    So the engine was running around 2 min out of every 15 minutes, or about 10 minutes per hour.
    _very_ low duty cycle!
  8. ChapmanF
    15,649
    They make CO monitors that only honk (somewhere around 400 ppm, if I remember right), and also CO monitors with a little ppm display on the front, that can show you much lower levels (mine, inside my house, can detect when the house across the street is having the carpets cleaned with the big truck parked out front).
    That lets you get a very good idea what magnitude of risk we're talking about (with a highly efficient 4 cylinder running two minutes out of every 15, outdoors), and decide whether it's even worth spending more brainpower on.
    -Chap
    John in Vermont and jerrymildred like this.
  9. glutaman
    glutaman Member
    73
    26
    Dublin, Ireland
    Very interesting. I wonder, would the Prime be able to keep the A/C working all night if the battery is full when "going to bed"?
    mmmodem and Data Daedalus like this.
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    We can only plead with you not to ruin your battery, we can't stop you. Stay in READY!
  11. Pijoto
    Pijoto Active Member
    199
    151
    Dallas, TX
    Camped out a ton in my Prius (mostly in the Mountains when it's cool at night), but only slept with the A/C on for a night or two.... one bit of advice, bring some earplugs to keep the sudden roar of the engine turning on from waking you up.
    regularguy likes this.
  12. ChapmanF
    15,649
    A/C won't run except in READY anyway.
    You could run the blower fan if you only wanted ventilation, and that could discharge the 12 volt battery if done outside of READY.
    Although it was for Gen 2, hobbit designed a blower controller to run the fan overnight at very low power for just a hint of ventilation. It would probably have to be checked against a Gen 3 wiring diagram before assuming it would work the same way.
    But no worries about discharging when using the A/C, because you have to be in READY to use it.
    -Chap
    4est and Data Daedalus like this.
  13. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    As mentioned, the A/C will not run anyway, but the Prius Prime (I assume the plugin hybrid) has an 8.8 kWh battery. That would be enough to run the A/C on quite a high setting for 8 hours and 16 hours during nighttime would not be so far fetched.
    Data Daedalus and glutaman like this.
  14. Johnny Cakes
    Johnny Cakes Senior Member
    1,017
    766
    Virginia, USA
    The noise of the ICE starting doesn't bother me. I have earplugs and even have a 5v "white noise" machine. The problem is the vibration or shudder for a brief second when the car is starting. Do other people not have that?
  15. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    I have taken several trips in my prius and sleep in it often. Just set the temp and use the auto feature. I choose to have the fresh air as opposed to re-circulating. One time I went to bed with the AC on and was surprised in the morning it was 38 degrees. the car switched to heat mode and kept the same temp inside the car as it was when I went to sleep.
    Re the shudder the car makes when starting the ICE. I set the parking brake firmly and that seems to help some. After the first or second night I stopped noticing it.
    plai7778, Data Daedalus and glutaman like this.
  16. Maarten28
    414
    224
    Netherlands
    Why would it surprise you that the car kept its set temperature? It always switches to heating when you have the A/C on.
    kc5dlo likes this.
  17. kc5dlo
    266
    163
    DFW TX
    2021 Prius
    Guess I'm stupid. At least I already know I'm ugly so that wont be a surprise later.
    m.wynn likes this.
  18. mmmodem
    2,732
    1,703
    Bay Area, CA
    Probably not. I went to a drive-in with my PiP. I think I had 5 or so miles and it ran out before the first movie was over. I didn't even use AC. I left the car in Ready mode in park. So it lasted maybe 3 hours max, there were a lot of trailers. I was pretty disappointed but assumed keeping the engine in Ready mode used a lot of electricity.
    Data Daedalus and kc410 like this.
  19. plai7778
    US
    For anyone referencing this thread. I leave it on 72 auto when it's not very hot (highs in the high 80s) leave it on 75 when high is 100 plus...step on the emergency brake so the car rattles less when the engine comes on to charge battery
    Data Daedalus likes this.
  20. ChapmanF
    15,649
    From my last sleeping-in-the-car experience, which was while the sun was up, I think I may pack a small fan in the future. With the sun up, despite the air conditioning, the heat radiating down at me from the roof as I lay in the back was hard to counter without running the A/C fan really high. With a small fan set up in back to move the air around me better, I would have been able to use much less excessive A/C settings.
    But that's mostly an issue for trying to rest during the day.
    -Chap
