how to secure spare tire after lock-down mechanism failed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dh65, Jun 24, 2024 at 8:50 AM.
  1. dh65
    dh65 Junior Member
    New York City
    Dealing with a flat tire yesterday I found that I could not unscrew the lock-down bolt that holds the spare in place. The plastic head on the bolt eventually turned but didn't loosen so I pried it off the bolt and found that the threaded piece of metal that the bolt screws into was corroded. Attempting to unscrew it with a wrench caused the whole mechanism to break (the threaded piece of metal broke). So now I've got access to the spare but no way to secure it in place after I get my flat fixed. Any thoughts about this situation? Is it unsafe to have the spare in there unsecured?
  2. ChapmanF
    15,402
  3. fragglestickcar
    66
    38
    New York
    Common problem. Been driving with the scissor jack bracket and spare tire unclamped for years. Hasn't bothered me in the slightest although I suppose in one out of a billion prius accidents, the scissor jack could fly with drone-like precision into my head.
  4. Tombukt2
    Tombukt2 Senior Member
    8,876
    1,549
    Durham NC
    It's not uncommon at all to drive with the spare not tied down in the back your car would have to get upside down for the spare to drop out and hit the headliner and then what You're upside down in your seat belt and all of that been there done that not with the spare tire but upside down in a car as in on the roof but still sitting in the seat after a wreck so if I'm not mistaken the stud is easily dealt with You can either cut the stud off drill the hole out chase the threads so that you have the I'm not sure what it is 6 mm or whatever hole and then get the new plastic nut or is it a plastic stud sticking out of the piece that goes and I have to go look I haven't moved the spare looked at it in years but you can easily recreate the hole for the stud or drill the stud out make a thread clean up the thread screw a new stud in lock tighted or put a dab of spatter on it from your TIG welder and now everything is restored or do absolutely nothing I don't even carry a spare that whole well back there is empty in all four of my generation twos If I have tire plugs and injectable Fix-A-Flat and air generally in the car and then the last 20 years I can't even think of having to use any of that usually when something's in the tire like a nail or a screw I wind up getting back to the house noticing the tires a little low and well there you go.
  5. Mendel Leisk
    38,634
    The welded nut in the well broke free? If so, maybe a replacement rivet nut?
    note to self: might be time to pull the spare out again, check it’s pressure. Put a drop of oil on that hold-down bolt too.
