How to set all locations of a particular Point of Interest?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by DavidA, Aug 14, 2019.
  1. DavidA
    2,328
    1,812
    Chicago western burbs
    Can't find this in the Nav. manual, but prior to my Prime (Advanced) having its 12v battery disconnected for service, I had somehow programmed in all locations of a few businesses in just a few steps. For example, all Trader Joe's, all Cracker Barrel Restaurants, and all Costco locations. That's actually what was set in my nav., even though it was about a thousand locations - I had done this once before and have forgotten how to accomplish this.
    Has anyone else done this successfully? I must have found a kludge in the interface, since all I can figure out now is how to set certain POI's one-by-one, or only along a programmed route.
  2. Tideland Prius
    16,157
    You had to navigate to POI, then set what POIs you want to display and then select the individual businesses.
    Select "Options" on the top of the screen
    Select "Change POI"
    Select "Other POI"
    Go into the respective categories you need and choose your businesses
  3. DavidA
    2,328
    1,812
    OK, thanks! I'll try this and check back afterwards.
  4. DavidA
    2,328
    1,812
    Success, sort of. The manual for the Nav. says that a total of 6 POI location types can be set (mapped with icons). The car can only do 5 of the 6. I don't know why this is, but it might be due to memory restrictions.
    The Nav. interface, as we all know, is a piece of crap in this car. So this took... a... long... time... to program.
    Tideland Prius likes this.
