How to shift to B gear
Discussion in 'Gen 3 Prius Main Forum' started by DJay, Mar 7, 2017.
  1. DJay
    DJay New Member
    Illinois
    I
    This is going to sound very stupid, but I don't see how to shift into B gear from D. It seems locked into place while I'm driving.
  2. ChapmanF
    15,435
    The shifter has a "rest" position, which is where it is whenever you're not in the midst of shifting with it. It always goes back to that sort of right, middle spot.
    So after you've shifted to D (left and down) ... and then let the shifter back to its rest spot ... B is straight down.
    -Chap
    Eve Barbanell likes this.
  3. DJay
    DJay New Member
    Illinois
    I
    Thank you! I'll check that out. So then to go back to D is straight up?
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No, that is Reverse.
    Drive is down and left
    Neutral is Left, but there is hardly ever a reason to be in N
  5. DJay
    DJay New Member
    Illinois
    I
    So if I'm in B gear, I shift left and down to go back to D? Just so that I'm clear, thanks.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No matter what gear you are in, the shifter goes back to the rest position once you let go of it. (the white circle in the picture)
    From the rest position, D is to the left a little and down.
    Eve Barbanell and Raytheeagle like this.
  7. Mendel Leisk
    38,644
    And N takes more effort: pull it over to "9 oclock", and hold it there for about a second. There's always confirmation on the dash, as to what gear you're in.
    I will occasionally use N, to roll the car's wheel into firm contact with curb, when parking on a hill. You could do it in D or R, but it's more controlled in N.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Supposedly, you use B when you're driving down hill so it'll recharge your HV battery, but I don't feel any benefit in it, or am I doing it wrong?
  9. Mendel Leisk
    38,644
    It's to reduce charging. To avoid a completely topped up battery, and the car falling back to using the friction brakes 100%, with a long downhill stretch still to go. It's not really well explained in the manual, for sure.
    I've never experienced this, even coming down our Mount Seymour. I do use B most of the way, go back to D on zones where the road levels out.
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The exact opposite actually. B adds engine braking to slow charging of the HV Battery. This keeps it cooler and keeps the disc brakes cooler later once the battery is 'completely' recharged and all of the braking falls to friction. Cool is good, boiling the brake fluid is bad. So B is a wise idea from the top of a long descent.
  11. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Your potential energy is your mass and elevation. It's not physically possible for B to recharge more than D.
    I'm observing different things in my PIP versus Mendel and Jimbo. The HSI indicates double or more magnitude in regen rate in B vs D. Of course, it's no more than if you lightly put your foot on the brakes. You don't actually get anymore regen but it's easier on your legs.
    I only experience engine braking when the battery gets hot or full.
  12. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    There are several reasons the Plug ins work differently than the hybrids
    1) much larger battery means that you can descend about 2000 feet before the battery fills, compared to 600 vertical drop in the hybrid.
    2)PHEV also has a much higher charge rate, so there is less excess energy lost that needs to be burned off in rotating the engine.
    As such, B in the Plug Ins is not all that similar to B in the Hybrids.
    mmmodem likes this.
  13. bisco
    49,371
    the shifter is spring loaded. when you let go, it returns home.
  14. Mendel Leisk
    38,644
    Yeah I think B in the plug-in is different.
  15. Fiss
    Fiss Junior Member
    Dallas
    The opposite. B is an engine brake. You would use it if you are going to be going downhill a long distance so you dont over heat the brakes. You wont be charging the battery as much. It's the same as if you were driving a normal car and put it into a lower gear to slow the car down.
  16. NutzAboutBolts
    1,476
    1,552
    Bay Area
    got it. Damn Toyota sells man, giving me the wrong info when we first bought our Prius:mad:
  17. Mendel Leisk
    38,644
    I looked in the Owner's Manual for something definitive, a good description of B mode, came up more-or-less empty. o_O Excerpt from page 174:
    What's known has been cobbled together, regarding diminished charging in B, and the need to use it on long descents to avoid (or at least postpone) running out of "regen braking".
    Very little from Toyota, at least in the Owner's Manual. Is there something spelled out, somewhere?
  18. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    From page 251 of my 2013 PiP manual -- Screen Shot 2017-03-10 at 3.47.29 PM.png
    mmmodem likes this.
  19. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    I just drive from Ohio to North Carolina. Went through the mountains, of course. I hardly needed to brake. Wierd.
  20. bisco
    49,371
    there may be more posts/threads about b mode, than any other feature. i don't think anyone really knows what it does.
    jerrymildred likes this.
