How To Steady Idle?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by john_dough, May 16, 2009.
  1. john_dough
    john_dough New Member
    75
    It appears that the ICE idles a bit rough---I noticed this after coming to a stop and pressing Park, the ICE ran for about 30 sec before shutting down.
    A search of this forum turned up an 8 step procedure from 2005 to achieve steady idle (for emission test or troubleshooting). I'm not sure it applies to my 2008 model---also, it seems that there must be a quicker yet safe way to have the car idle at it's normal idle rpm (1500 rpm???). Any ideas? Thanks.
  2. cmar
    cmar Junior Member
    Southern California
    I am sure other more qualified will respond, and this does not answer your specific question, but all prii I have driven in (3) have a stage where they idle rough.
    When they are in between being cold and sufficiently warm, the motor idles rough, sounds a little like a diesel, and shutters before shutting down.
  3. richard schumacher
    7,663
    1,038
    United States
    Unless you get a check engine or other warning light this is completely normal. Don't try to defeat normal operation.
  4. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    See The Five Stages of Prius Hybrid Operation. Once fully warmed up to above 73ºC, the car starts looking to do an idle speed check. It won't switch the engine off when it's running, and the car is travelling below the EV speed limit (34mph). It can't actually perform the idle speed check until you slow down to below 6mph and let the engine idle - so don't press the accelerator at all. This idle check takes 10 seconds from the moment the car goes into idle. For some reason the shutdown after completing the idle speed check is very, very rough. After this, though, engine startups and shutdowns are very smooth.
    It seems to need an idle speed check once per driving cycle. Once complete, it appears to run the engine at lower speeds when engine demand is low, leading to lower fuel consumption when cruising.
    If the car is travelling faster than 34mph, it will cut the engine as you slow down (fuel cut over 42mph, total stop below that speed). Very occasionally I've seen it start the engine to do the idle check when dropping below 34mph, but often the engine stays stopped.
    I don't recall the engine ever staying on for as long as 30 seconds once warmed up, unless the cabin heater is set to a particularly high temperature. Cabin heat comes from hot engine coolant circulating through the heater core in the HVAC system. It's also possible that you had high electric demands, for example running the air conditioner to cool the car.
