How to switch between bluetooth phones
Discussion in 'Prius c Audio and Electronics' started by Tony Dias, Jan 23, 2013.
  1. Tony Dias
    Tony Dias Junior Member
    Does anyone know how to switch between two different bluetooth connected phones?
    I generally have to turn off bluetooth on one phone and then go to the paired list after the unit fails to connect to the first phone, but this seems odd and I would think there's a better way to switch between bluetooth audio sources.
    TIA
  2. DoPeY5007
    DoPeY5007 Member
    122
    17
    From what I can tell, it is one at a time. Kind of a pain. I just forward my 2nd # to my main.
  3. poser
    poser Junior Member
    Alberta
    That's stupid, I have two phones in there at all times. I hate it. Work calls and I'm not hooked up or personal calls and aaaaargh
  4. MBRGuru
    MBRGuru Member
    255
    26
    You can select which device to connect using the Bluetooth settings in the SETUP menu. Have you tried this?
  5. DoPeY5007
    DoPeY5007 Member
    122
    17
    That would not work for me as I carry two phones all the time. I had a Blueant headset with multi point so it would work on either phone that rang.
    So far, the best option is have one forward to the other (I have moved to this solution for the last few months anyhow)
    poser likes this.
  6. MBRGuru
    MBRGuru Member
    255
    26
    Ahh, yeah only one device per profile at a time.
