How to take care of Prius when not in use?
Discussion in 'Gen 3 Prius Main Forum' started by kamrul, Mar 31, 2019.
  1. kamrul
    kamrul Junior Member
    98
    17
    Bangladesh
    I just bought a Prius 2013. The car has about 62K KMs on the ODO (~39K Miles). Currently, it is sitting idle in my garage. I start the car usually at night, put the AC on auto and just keep it that way for 15-20 minutes. During this tenure, engine automatically kicks on, charges the battery one bar and shuts off. I have been doing this almost daily, once a day for past one week as it has not been taken out of garage.
    Is this a good practice? I have read that letting the car sit idle for too long doesn’t do good to the hybrid battery.
    51,155
    there's no science. once a week should be fine if you can put a tender on the 12v.
  3. Mendel Leisk
    40,584
    I would take it for a good drive at least once weekly, say 10 kms minimum, use the AC a little, to circulate it's oil. The rest of the time let it sit in the garage, with the 12 volt battery hooked up to a smart charger (3~4 amp range), one that can be kept on indefinitely if needed.
    frodoz737 likes this.
  4. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    I have been storing two Prius's for six months at a time for a number of years. I have the oil changed before putting the vehicles in storage and I make sure the drive battery is close to or fully charged. I leave a battery tender on the 12-volt battery. Neither vehicles are started during the 6-month storage periods. The only concern I have is that usually the engine knocks for a few moments when they first start up. I have talked to the dealer about the noise and they tell me if they don't hear it, they won't do anything about it.
    FuelMiser likes this.
  5. bettergolf
    bettergolf Active Member
    478
    361
    Sanford NC
    I'd say the brief knocking is not a problem, just a result of all the oil on the components having had 6 months to run off and down into the oil pan. At that point they aren't well lubricated and will be noisy. As soon as oil is recirculated throughout the engine upon starting it, the noise should stop. Technically you're hearing engine wear, but it should be negligible over the life of the engine as long as you're not revving the engine while it's making noise.
    kamrul likes this.
  6. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I don't think a single day would count as having the car sit idle for too long. IMHO doing this daily or every other day does more bad than good. You are starting from cold every time with all the wear that is connected with it.
    There is no need whatsoever to keep the hybrid battery charged like that. It should not discharge that much.
    Maybe if you do it every month I could understand it.
    kamrul likes this.
  7. orenji
    orenji Senior Member
    5,886
    3,487
    Every month is too little. Once a week more likely.
  8. Maarten28
    415
    224
    Netherlands
    I've had my car sit idle for 3 weeks during my holiday. No effect whatsoever.
