How to tell if Gen 1 Prius has original or proper catalytic converter?
Discussion in 'Generation 1 Prius Discussion' started by War_Destroyer, Sep 17, 2022.
  1. War_Destroyer
    War_Destroyer Junior Member
    22
    Los Angeles
    2002 Prius
    So I have a 2002 Prius that I bought last October, it's treated me very well, but I do wonder if it has it's original cat, or had proper replacement at some point. I haven't had to SMOG it yet, but I do wonder. Everything seemed equally worn when I took a peak, nothing seemed hacked in or out. The car does have less than 65K miles, and looks fantastic and well take cared of. Do you guys know how I can properly identify the cat?
  2. Josey
    Josey Active Member
    290
    111
    Virginia
    2003 Prius
    Visual inspection is how might be able to tell if it's original or at least oem equivalent. Good pictures and stuff can be found here:
    Prius 1st Gen – Replacing the Catalytic Converters
    As far as functionality goes, you'd need to look at the O2 sensor data. If you have even a low end scantool that provides live data, sit at idle and pull up the streams from the 2 O2 sensors. The upstream sensor (often "sensor 1" on a scanner) should be fluctuating quickly and regularly between about .1V and .9V. The downstream ("sensor 2") can exhibit some fluctuation, but should be mostly inactive.
