How to tell if my catalytic converter is stolen?
Discussion in 'Gen 3 Prius Main Forum' started by Happy_Prius_Owner, Nov 28, 2020.
  1. Happy_Prius_Owner
    Happy_Prius_Owner New Member
    San Francisco
    Sadly, like some members here, the number of cat converter thefts is on the rise in my area. I have TWO Gen 3's and they are parked on the driveway. I have a pretty bright motion-sensored porch light, but I heard that the culprits are not deterred. So, I think it's only a matter of time when mine get stolen.
    Due to an injury, I cannot bend my body to look under the car. So, how will I be able to tell if the cats are stolen when (1) the car is not running and (2) the car is running? Many thanks.
  2. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    Well not sure, but they are cutting away your exhaust pipe, so I presume it would sound a little like a older Boeing 747.
    However, I am not sure the car would even start without errors because you would lose your temperature and O2 readings the hybrid system is looking for.
    Majafamily and Happy_Prius_Owner like this.
  3. Grit
    Grit Senior Member
    6,141
    4,053
    Wilkes Land
    That excuse is not good enough. I was in a push-up position and couldn't even visually see the converter either.
  4. Grit
    Grit Senior Member
    6,141
    4,053
    Wilkes Land
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    How about a mirror on a pole;).
    Should be able to do the trick(y).
    Majafamily and Grit like this.
  6. Grit
    Grit Senior Member
    6,141
    4,053
    Wilkes Land
    Great idea. I thought about after a drive, put marshmellow, chocolate, grahmcracker mounted to stick then hold it near the converter location. If it's still there, it should be a least 1000F and make instant s'mores :LOL:
  7. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Just start it. It will be very loud. No need to look at it. There are steel cages becoming available to protect the cat if desired. The exhaust pipes are easy to cut with a battery recip saw. Steel is not.
    jerrymildred likes this.
  8. bettergolf
    bettergolf Active Member
    417
    334
    Sanford NC
    "and couldn't even visually see the converter either"
    Is there a way to see other than visually?
  9. Grit
    Grit Senior Member
    6,141
    4,053
    Wilkes Land
    I use a cell phone on a self stick at times to see under the car. That’s another way to see it visually not using my eyes.
  10. Austin Longenecker
    123
    66
    Austin Tx
    I guess technically using a thermal camera will allow you to see beneath in a way that is not visual. The Infrared the camera picks up does not fall under the visual light spectrum. (Now of course the image representation is visual). Does that count?
    Grit likes this.
  11. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    You beat me to it. Just start it. You'll know it the instant the ICE fires up. Absolute quickest way to tell if someone cut a chunk out of your exhaust system in front of the muffler. But if you're deaf, it might take a little longer before a neighbor finally comes over to see what the heck you're doing.
    Prodigyplace and Merkey like this.
  12. rjparker
    7,918
    4,680
    Texas Hill Country
  13. BZzap!
    BZzap! Senior Member
    1,607
    877
    I would assume that the exhaust note would be very loud. Another clue would be no exhaust pressure at the tail pipe when the engine is running.
    wjtracy likes this.
  14. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    Turn it on. It'll sound like a tractor. Give it gas, and your neighbors will open their windows and throw tomatoes at you.
