How to turn off alarm after changing 12V battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Katya S, Feb 15, 2018.
  1. Katya S
    Katya S Junior Member
    Usa
    I looked everywhere but couldn't find my exact problem maybe anyone here can help out.
    A few days ago I woke up to my Prius nonresponsive, so we assumed the issue is the Aux Battery, so my uncle bought one and replaced it (he's not a mechanic but he has done it successfully on a gen 3 Prius before and this problem didn't arise).
    To open the back in had to squeeze in from the front and use the trunk latch, and we have pretty much finished the replacement sans a few decorative screws.
    But when he connected it to the -, the lights and alarms went OFF which was not good in a subdivision at night.
    How do I stop it? I tried inserting the plastic key thing in and out and click the buttons on it(it is charged because the little light on it goes off), but that didn't really contribute much.
    Any help? Thank you.
  2. Stevewoods
    Stevewoods Senior Member
    659
    1,133
    Seattle, WA
    So, to try to take this logically, what has changed?
    You put in a new battery.
    I know you have a new battery, but I might suspect it has some issue that might be causing a voltage fluctuation.
    Just cause something is new, doesn't mean it might not be good.
    Number two, just a quick google on this forum shows that someone suggested pulling the dome light fuse for a few minutes, apparently it has something to do with the alarm power.
    It is in post #6 in this thread:
    Reset alarm after battery boost? | PriusChat
  3. Katya S
    Usa
    Not really an update since I haven't tried anything yet, but I just realized that the week before that the car would flash the door open signal light whenever I started driving from a streetlight, I didn't even realize it at first since the light would light up for a fraction of a second. Could this be related somehow???
    51,927
    perhaps a door switch is not contacting properly, and drained your 12v. usually, it's the hatch.
    is it an aftermarket alarm?
  5. Katya S
    Usa
    I will look into the origin of the alarm later today. Are all doors and the trunk supposed to be closed after I reconnect the battery? I'm afraid I'll just lock myself out and have to spend a good 2 minutes getting back into the car to open its trunk and disconnect the battery to stop it yelling ;(
  6. Prodigyplace
    12,560
    11,778
    Central Virginia
    The instructions should be documented in the manual for the alarm system. I am not aware of any Prius alarm system supplied by Toyota but some dealers install aftermarket ones.
  7. Katya S
    Usa
    I will try the procedures for deactivating the theft alarm soon (at an earlier hour maybe haha). I hope me forcing the back open with the latch won't be a problem :S
    Thanks to everyone for help and I'll update the thread with what fixed it for me (if it does).
    Prodigyplace likes this.
  8. Prodigyplace
    12,560
    11,778
    Central Virginia
    If you know what dealer originally sold the car, they should know the procedure too.
  9. bisco
    51,927
    i would first check the 12v health. once you know it's good, you can close and lock everything with confidence.
    fiddle with the hatch closing while someone sits in the drivers seat watching for the light.
  10. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Press lock/unlock on the keyfob several times. That worked on a 2008 with the factory alarm.
    bisco, Prodigyplace and SFO like this.
  11. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Linked, if you can't locate the manual : 2005 Toyota Prius Owners Manual and Warranty - Toyota Owners
    Raytheeagle likes this.
  12. Stevewoods
    659
    1,133
    Seattle, WA
    As mentioned by others, sounds to me like a door/hatch contact issue.
  13. Prodigyplace
    12,560
    11,778
    Central Virginia
  14. Katya S
    Usa
    The lesson of today is read the manual, it was the theft deterrent system and was turned off rather easily by unlocking the car with the key. Thank you so much everyone who helped, you guys are the best :)
    SFO and Prodigyplace like this.
  15. Farsan
    Farsan New Member
    Sweden
    Hi Katya, I am having the same issue as you. You mentioned previously that inserting the plastic key and clicking the unlock button did not work. Could you please clarify how you managed to fix it?
  16. sub3marathonman
    sub3marathonman Active Member
    557
    75
    And, even over six years later, your helpful update solved the problem for me. I thought putting the FOB in the ignition would stop it, but no, but the little key unlocking the door did it.
  17. ChapmanF
    18,189
    Yeah, the alarm was unconscious while the battery was dead. The last thing it knew, the car was all locked up and armed, and now it wakes up and sees a door or hatch open, and it never saw you use the key or fob to unlock it.
    When it has happened to me, I've also been able to silence it just by pushing the unlock button on the fob. Not sure why that wasn't working upthread.
  18. dolj
    dolj Senior Member
    8,446
    4,290
    Wellington, New Zealand
