How to turn off seat belt beeper
Discussion in 'Gen 2 Prius Main Forum' started by Seagull6, Oct 6, 2006.
  1. Seagull6
    Seagull6 New Member
    42
    I turned off the backup beeper today and was under the (wrong) impression that the procedure also turned off the seat belt beeper. Could someone please direct me to the instructions for turning off the seat belt beeper?
    Thanks!
  2. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
  3. Seagull6
    Seagull6 New Member
    42
    Rangerdavid, thanks, I didn't read down far enough when I went there the first time. I don't ever drive without a seat belt, but my dog rides in the passenger seat and is constantly moving around, setting off the beeper at various times during our trips. :)
  4. wtfjr
    wtfjr New Member
    38
    Your dog rides in the front passenger seat ?
    I'd suspect that the law requires him [the dog] to also be seat belted in ??
    He'd make a huge hole in your windshield if you had to suddenly stop.
  5. dumas
    dumas Junior Member
    44
    NC
    <div class='quotetop'>QUOTE(wtfjr @ Oct 6 2006, 08:46 PM) [snapback]329238[/snapback]</div>
    It wouldn't do the dog much good either.
    I always felt better with the dog in a harness, securely tethered in the back seat.
  6. janetjanetbobanet
    janetjanetbobanet Junior Member
    52
    Wichita, Kansas
    When I have heavy stuff in the passenger seat I just fasten the seat belt together so it doesn't beep before I put the stuff there. Would probably work for your dog, too.
  7. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    If you want to turn off the passenger seat warning, make sure to sit in it when you go through the process of buckling and unbuckling the belt.
  8. dancekat59
    dancekat59 Member
    244
    <div class='quotetop'>QUOTE(Pinto Girl @ Oct 11 2006, 06:44 PM) [snapback]331451[/snapback]</div>
    I just did this and it's quite tricky trying to do this by yourself. ;)
