How to turn off the reverse beeping
Discussion in 'Knowledge Base Articles Discussion' started by randreed, Jul 19, 2006.
  1. randreed
    randreed Same as it ever was . . .
    605
    West Milford, NJ
    To disable the current reverse beep for the Prius:
    1. Power on the car to IG-ON or READY. IG-ON will do for this purpose.
    2. Using the Trip/ODO button, set the Trip/ODO display to ODO (not Trip A or Trip B)
    3. Power off the car.
    4. Now power the car to READY (brake on). This is required so that step 6 works correctly.
    5. Within 6 seconds of powering on, press and hold the Trip/ODO button for 10 seconds or more.
    6. WHILE STILL HOLDING ODO *after* the 10 seconds, shift the "gear" selector from P to R, then back to P. Now release the Trip/ODO button.
    7. If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip Odometer or Odometer is normally displayed. "b on" is beep on, and "b off" is beep off.
    8. Press Trip/ODO to toggle the mode.
    9. Now power the car off to exit the toggle mode.
    10. Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if "b off" was selected, and should be audible if "b on" was selected.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Use the same procedure for the seat belt beep, just buckle and unbuckle the seat belt instead of the Park Reverse thing in step 6. Note: if you are doing the passengers seat belt you can't have anyone in the passenger's seat or it won't work.
    George W and ishootstuff like this.
  3. George W
    George W Senior Member
    933
    519
    San Antonio
    Both steps worked om my Gen 2. Thanks for posting!
