How to turn on the headlights, a detailed step-by-step guide.
Discussion in 'Prime Main Forum (2017-2022)' started by chogan2, Feb 24, 2023.
  1. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    This post is for your amusement, as I am almost certain I'm that my wife and I are the only drivers in North America to have made this mistake.
    In a nutshell, I have driven my wife's Prius Prime for close to a year and a half. I just now figured out how to turn on the headlights.
    As a bonus, I've also finally figured out why the Prime has such lousy high-beams. (Wrong.)
    And I blame it all on Canada.
    Here's the story.
    OK, so I'm old. I'm set in my ways. I don't interpret icons very well. I drive almost exclusively on well-lit suburban roads. I'm an American. And I will only RTFM as a last resort.
    As a result, I operate the standard features of this car way I've operated every other car I've ever owned.
    Every car I've ever owned, the light switch went from off, to parking lights, to on (headlights and marker lights).
    Two clicks, from off to on, passing through "parking lights".
    And you could tell the difference between parking lights, and on, because the headlights come on. By definition, the headlights are off when the switch is set to parking lights. That's what defines parking lights. Just the marker lights are on.
    So, working on instinct, I get in the car, in the dark, turn the light switch two clicks. I can see that the headlights are illuminated. So, the headlights must be on, right? I'm good to go. (Wrong.)
    These Canadian-style DRLs, well, they're just parking lights plus headlights on low, right? (Wrong.)
    So, presumably they replace old-style parking lights, right?. (Wrong.)
    Because I can see that I don't have (American-style) parkign lights, because the signature feature of parking lights is that they illuminate your marker lights, but not your headlights, so that everyone who sees your vehicle knows that you are parked, and not moving.
    Everybody knows that, right?
    But, golly, turning the light switch that last click, to turn on the high beams -- that seems to do next-to-nothing. Must be some generic issue with LED headlights or something. (Wrong.) Luckily, where I drive, I don't need them.
    I will say, however, that my wife -- who, by the way, did the exact same thing I did -- had been complaining that her night vision isn't what it used to be. But, eh, that's probably true, to a degree. Mine too. Heck, just fill in the blank. My ____ isn't what it used to be. Chances are, that will be true.
    So I thought nothing of it.
    In my defense, after 1.5 years of driving around, at night, in the burbs, on the "parking lights" setting (second click), nobody ever flashed their lights at me to tell me that I had my lights off at night. So whatever I was doing, to other drivers, it at gave a pretty good imitation of driving with my lights on.
    But I've been trying to take a little more care to understand all the features of the Prime, even if I'm never going to use them. So I was looking for the instructions on the automatic high-beam dimmer.
    And that's when I pieced together that on this car, it's three clicks to headlights. High beams are based on stalk position only.
    Clearly labeled in the manual, the light switch positions are off, DRL, parking, headlights. Three clicks for headlights.
    The upshot is that after a year and a half, I've finally learned how to turn on the headlights.
    I blame Canada.
    #1 chogan2, Feb 24, 2023
    lbligh likes this.
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    I funny and wonderful read! Thanks!
    lbligh likes this.
  3. Mendel Leisk
    42,369
    Up here day time running lights come on automatically (maybe as soon as you shift outa park); there's no turning them on/off the light stalk. So yeah up here it's as you remember and prefer: off/parking/on, and a fourth option: automatic. The latter turns 'em on/off depending on ambient light, and will shut them off when the car's turned off (after a delay, default is 30 seconds IIRC).
    I'm old-school, so never use that last setting. Nor the parking lights only setting either, just too easy to forget and drive off without headlights. I think with parking lights only you still get the (falsely) reassuring headlight on icon on the dash.
    One time we rented a car in the States, the light switch was a dial on the dash. Spent a solid 10 minutes trying to find it. On a Chrysler 300.
  4. Trollbait
    12,832
    At least you got the parking lights on with the DRLs.
    I regularly see people on my way home with just the DRLs on. You can tell its DRLs because their tail lights are off. I guess a fuse is blown, and they are driving around without a lit dashboard too.
    With the Outback, Camry, and Sonic, the switch was off, auto, parking, and headlights. Auto had DRLs on, but it might have been possible to turn them off in the settings. I don't recall how the switch was set on the Prius or Matrix, but they had the light sensor. The Matrix seemed to have no way of turning off the DRLs.
    The Sonic had a spring in the switch, so it turned back to auto after turning things off. Wanted the lights off, had to turn them off every thing the car started. GM has lobbied the NHTSA to make DRL mandatory in the US like they are in Canada.
    I just leave things on auto now, unless there is rain or fog not dark enough to trigger the lights on. Didn't cars use to have a separate on light for the parking lights?
  5. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    … assuming it is 2021 or earlier. If I have not mistaken, Canada has a new law for 2022 vehicles with “always on” tail lights as well to deal with “phantom cars” - people who drive with DRLs at night and no tail lights. o_O
    My PiP has 4 headlight settings - OFF, Parking, ON, and Auto. I almost always leave it on Auto and it does its thing well (and I believe there are sensitivity settings that can be played with, which I haven’t touched in a long time). The only time I manually go to ON is if I want to forced them on at dawn or dusk, or during inclement weather, etc. (y)
    (Is it weird every time I hear “Blame Canada” I think of South Park? :ROFLMAO:)
    Tideland Prius and Mendel Leisk like this.
  6. Mendel Leisk
    42,369
    Not on my 2010, and I suspect it's still the case. Maybe @Tideland Prius will comment. Basically, if I have the light stalk set to off, as soon as I start driving, I've got just the high beams, at reduced brightness, no parking lights, brake lights only light when you step on brakes.
    You'll frequently see people driving thus around here, just the reduced brightness highbeams lit, in the dead of night. Apparently the lit up dash is still bright enough to sucker them in to thinking their head lights are on. Especially when there's good street lights, and you don't notice reduced brightness. From behind they're pretty much black..
    See a lot of what I say overlaps with @Sarge. Concur about South Park too...
    Tideland Prius likes this.
  7. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Well, Subarus retained exactly that until pretty recently as I recall. And I recall that it was an override switch. You could get parking lights on by twisting the left stalk one click, but they would cut off when you shut down the ignition. If you hit the rocker switch on top of the steering column, it would override and put the parking lights on via B+.
    The oldest car I've owned was a 1958 and its headlight switch was combined with the parking light switch, as was everything after.
  8. Mendel Leisk
    42,369
    For a change of pace, 58 V-Dub (first car I drove, with learner's license):
  9. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Nice, I had a '59.
  10. Washingtonian
    Washingtonian Senior Member
    726
    621
    It is actually more complicated than the OP has mentioned. I think it varies between the models of the PP, but he indicates he has a 2005 Prius. There are two rotary switches on the stalk, and the inner one is used to turn the fog lights on or off. Then there is another switch on the dash, left of the steering wheel next to the HUD switch that turns the automatic high beams on or off. And if you turn the rotary switch to AUTO and press the high beam switch, the lights will come on when it gets dark and go off when you turn off the car and automatically dim when you approach another car. I did have to RTFM to learn this as I was wondering why the lights seemed so dim when the wife was driving.
  11. Trollbait
    12,832
    Should have quoted the OP there I guess.
    DRLs are pretty much standard on cars in the US, but their use is not mandatory. Cars without auto headlights, like the OP, can easily have the DRLs on without the parking lights. Even with auto equipped it can happen. Noticed the lights dim when driving with my aunt. Her friend was driving the car earlier , and had switched the lights off from auto.
    This wasn't clear, because my post wasn't clear. I was talking about the lights on indicator light on the dash. I was wondering if the parking lights had one separate from the headlights in the past.
  12. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    The North American Gen 5 Prius has three different light switches:
    • USA Type A: off, DRL, parking, headlight
    • USA Type B: DRL off, auto, parking, headlight
    • Canada: auto, parking, headlight
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Every time I drive after dark around here I see at least three cars with no lights on whatsoever. Makes me wonder how many I DIDN'T see. :eek:
    Trollbait, bisco and Mendel Leisk like this.
  14. bisco
    52,891
    funny you mention this. we have seen at least 20 cars without their lites on in six weeks here in orlando.
    is it a florida thing? i thought it was all the drinking
    jerrymildred likes this.
  15. Washingtonian
    726
    621
    It used to be that driving at night w/o headlights on was how the police found most drunk drivers. Now it just means an old person in a new car.
    chogan2, Sarge, jerrymildred and 2 others like this.
  16. bisco
    52,891
    no cops around here to pull anyone over, haven't seen one yet
  17. Montgomery
    2,254
    2,244
    Orange County, CA
  18. Tideland Prius
    16,683
    That's correct but it's linked to the parking brake. I know, because when I had to leave a certified dark area, I had to drive with my left foot on the parking brake far in enough to engage the ((!)) light but obviously not far enough in to actually engage the parking brake. I did that to leave the area in completely darkness before I could turn on my lights once I was on the road. Windows were down and I yelled "moving car!" before I backed out of the parking spot and slowly moved through the field.
    Yes there's a new law that took into effect Sept 2021 that deals with phantom cars in Canada. There's too many carshare Prii with no taillights because the people driving them aren't familiar with newer cars so they see the bright digital dash and the bright LED DRLs and assume everything is fine.
    Toyota Canada took the easy route and used the LED low beam headlights as DRLs for the Prius c, Prius, Corolla, Sienna and I think the RAV4 too. This means all these drivers that aren't familiar with these cars will be driving with their lights off. Worse still, some dealers locally physically twist the stalk to the OFF position (probably a legacy SOP to prevent draining the 12V battery in customers' cars cause probably that happened at some point) so these cars will exit the service bay with the headlight in the OFF position and the owner might think it was still in AUTO.
    For 2022 MY onwards, there are 3 options for manufacturers to utilise.
    Toyota took the easy route again and just made all the lights turn on (so taillight and DRLs..... probably parking light too I'm not sure). So option #1
    On my EV6, it's actually set up the way I prefer (option #2). If it's dark outside (or I'm in a parkade or tunnel etc), the full set of lights (option 2) will come on whether the headlight stalk is in the OFF or AUTO position so it's impossible to drive with the taillights off if it's merely dark. (Although I will say, I have had to manually turn on the headlights in the rain during the day when it isn't dark enough). Also, because the rear indicators are red (grr) instead of amber, having the taillights off give a better chance for my indicators to be seen.
    Also, I don't know if it's a Kia thing or if it's a Canadian regulation for 2021 onwards but my EV6 has both a "parking light/taillight on" light and a "headlight on" light on the dashboard. All of my Prii only have a "parking light on" light so you wouldn't know if your headlights are on if you had a model with LED DRLs that used the headlight. Note that this is different from the U.S spec cars that have a "headlight on" light but no "parking light on" light on the dashboard.
    Sarge, Trollbait and Mendel Leisk like this.
  19. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    My switch goes OFF, AUTO, PARKING, ON. In low light conditions (dawn, dusk, weather, etc.) I prefer Parking to Auto because I will have the tail lights on. When it gets darker and I need the full head lights to see the road, etc., I will switch to ON.
    Trollbait likes this.
  20. ChapmanF
    19,054
    Is that a sure thing? Just for some generations, maybe? I'm not sure it's always the low beams.
    Gen 3 liftback was sold with either an all-halogen system or with LED low beams and halogen high beams. Its wiring diagram shows the DRL system running the halogen high beams, at pulse-modulated reduced brightness. So that works the same regardless of which flavor of low beam you have.
    And it kind of makes sense to me ... low beams are deliberately aimed down so you don't dazzle other drivers' night-adjusted eyes, but in daylight a dimmed high beam isn't going to dazzle anybody, and is probably the better aimed to be seen.
    Gen 1 and the halogen flavor of Gen 2 both used dual-filament single bulbs, so it wouldn't be super easy to tell by looking whether it's using the low or high beam filament. (You couldn't have DRL in a Gen 2 with HID, at least not according to the 2004 US New Car Features manual or wiring diagram.)
    The Gen 1 and Gen 2 wiring diagrams don't help much, because they both put the PWM DRL dimmer on the common line from the dual-filament to ground, so it would be happy to run either filament at low brightness, depending on which way the DIM relay is flipped.
    Both the Gen 1 and Gen 2 NCF do say it's the low beams. The Gen 1 wiring diagram doesn't say anything about the state of the DIM relay output when the DRLs are on. The Gen 2 wiring diagram says "sends daytime operation request from TERMINAL DRL/DIM." It doesn't say what "operation request" means, but the diagram shows TERMINAL DRL/DIM pulling down the DIM relay coil, which activates the high beams, so if that's what they mean by "daytime operation request", then it's the high beams. The people writing the docs might not all have been on the same page.
    Both Gen 1 and Gen 2 have separate H-LP LO and H-LP HI fuses, so maybe the easiest way to be sure for Gen 1 or Gen 2 would be for somebody with the DRLs to pull one side LO fuse and the other side HI fuse and see which side of the car has working DRL. :)
    #20 ChapmanF, Feb 25, 2023
