How to unlock all doors from driverside SKS
Discussion in 'Gen 2 Prius Main Forum' started by NinnJinn, Nov 1, 2013.
  1. NinnJinn
    NinnJinn Member
    276
    Indiana
    If I open the passenger side door or the hatch with the fob in my pocket, all doors unlock. If I open driver side door, no other doors unlock unless I push the unlock button on the fob or inside the car.
    Is there a way to unlock all doors from the driver side without physically using the fob or unlocking from inside the car?
    Thanks
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    retneprac likes this.
  3. usnavystgc
    3,159
    989
    Tucson, AZ
    Hey Ninn,
    Try this,
    Step 2. Turn the car off if it is on.
    Step 3. Be outside the car with the doors closed; The 'lock' button (with the closed padlock symbol), and the 'alarm' button (a speaker symbol with lines radiating from it) need to be pressed simultaneously for "about five seconds". You may hear one beep coming from inside the vehicle, but you should hear two double-beeps from outside the car. Release the buttons. If you hear a pattern other than two double-beeps, press the buttons again for another five seconds... And again if necessary. Once you hear the two double-beeps, the SKS should be in the 'all doors unlock' mode.
    Step 4. Test it.
    If that doesn't work, let me know.
    David Wells likes this.
  4. usnavystgc
    3,159
    989
    Tucson, AZ
    CHANGING THE DOORS TO BE UNLOCKED
    Each time you push the lock button
    together with the panic button on the
    smart key for about 5 seconds with the
    hybrid system off, the setting for door
    unlocking will change as follows:
    1. Driver’s door unlocking mode: If you
    perform smart unlocking operation on
    the driver’s door, it will unlock. Performing
    unlocking operation on the
    front passenger’s door or back door
    will unlock all the doors. When the
    system switches to this mode, one
    beep sounds inside the vehicle and two
    beeps sound three times.
    2. All doors unlocking mode: Performing
    smart unlocking operation on either
    front door or back door will unlock all
    the doors. When the system switches
    to this mode, one beep sounds inside
    the vehicle and two beeps sound twice.
    3. Single door unlocking mode: The
    driver’s door or back door on which
    you perform smart unlocking operation
    will unlock. However, performing unlocking
    operation on the front passenger’s
    door will unlock all the doors.
    When the system switches to this
    mode, one beep sounds inside the vehicle
    and two beeps sound once.
    This is the excerpt from the owners manual
  5. usnavystgc
    3,159
    989
    Tucson, AZ
    If you need a pdf of the owners manual, pmail me and I'll shoot it to you. :)
  6. NinnJinn
    NinnJinn Member
    276
    Indiana
    Thanks! It worked the first time I tried it!!!
  7. Prius904
    Prius904 Junior Member
    48
    very neat to know, good question and thanks for the answers!
  8. usnavystgc
    3,159
    989
    Tucson, AZ
    Good. Glad I was able to help someone, Lord knows enough people have helped me.
  9. retneprac
    retneprac Junior Member
    17
    Champlain Valley, Vermont
    It worked on my '07! I read the owners' manual --obviously need to read it again.
    Thank you ---you guys are great!! I've been gritting my teeth about this for weeks.
