How to unlock the Prius with iPhone/iPod touch?
Discussion in 'Gen 3 Prius Main Forum' started by macmaster05, Dec 16, 2009.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I need to know the iPhone hack that enables owners to unlock the Prius doors and hatch. What's the software and program called? Thanks.
  2. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    I seriously doubt that such a program exists. It would be nice though!
  3. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    So, having your keys or fob on you then simply touching the door isn't good enough, you'd rather unlock your iPhone, wait for an app to load, and then hit a 'button' on the iPhone? I don't get it?
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    It's a MYTH. Use the FOB, that's why they sold it to you!!!!
  5. 'E'
    'E' Erik
    56
    Las Vegas
    Mercedes Benz has an app for the iPhone that connects to it's OnStar-like service. You can remotely lock, unlock, or locate your car via gps. It could probably be possible with a Prius that has the S.O.S. feature but I doubt it'll ever happen.
  6. KK6PD
    4,003
    946
    118
    OK you piqued my interest, I first thought this was another "Hold the FOB up to a cellphone, and have the person you are calling hold the phone up to the car to unlock it question"
    Which will ABSOLUTLY NOT WORK, by the way.
    I did pick up the phone however and called Toyota, spoke to a fairly informed person who said while the "Onstar" system will unlock a GM's doors, it will NOT do so on the S.O.S. system, it was NEVER designed to do that, and there are no plans to modify the service to enable that particular function....
    Which is actually too bad, that would have been a nice "Extra"!!
    Oh well Back to FOBBING merrily along!!!
  7. ToyotaFleetManager
    ToyotaFleetManager New Member
    160
    92
    Houston
    The person you spoke to about the door unlocking feature of safety connect misinformed you. Safety connect can unlock the doors of any Toyota with safety connect and is smart keyed equipped.
  8. bwilson4web
    16,352
    Duct tape or epoxy works.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Perhaps if you throw it hard enough against a window, although an older brick type phone is better for this application.
    Tom
  10. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    It's the same software that makes popcorn with four iPhones.
    Spoofware
