How to up the window without turning on the engine?
Discussion in 'Prius c Main Forum' started by highroller, Jul 6, 2014.
  1. highroller
    highroller Junior Member
    78
    Sometimes I forgot to up my window before I turn off the engine. I cannot up my window being in accessory mode neither. Any way to go around this?
    It allows only around 20 seconds after power down to up the window, not after that.
    49,508
    i think you can up it after powering down, but before opening the door.
  3. highroller
    78
    No, not if it is after 20 seconds or something.
    49,508
    correct.
  5. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Use Accessory mode. Press the Start button with your foot off the brake, then press it a second time. Roll up the windows, use your wipers, etc. Then press the Start button, again with your foot off the brake pedal, to turn off the car.
    SCH-I535
  6. highroller
    78
    I don't have start button.
  7. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    just move the key to the on mode, the position right after ACC but not cranking.
    Fahfoofnik and ztanos like this.
  8. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    **Some thinking and remembering may be required**
    AliIzad likes this.
  9. orenji
    orenji Senior Member
    5,884
    3,486
    Keep the windows closed, no more issue!
    NDcowPoke likes this.
  10. HotDogWater
    HotDogWater Junior Member
    70
    17
    yep, one click past accessory mode is "on." you should be able to roll your windows up without starting your car then.
