How to use fan without A/C in 2005 Prius?
Discussion in 'Newbie Forum' started by sain, Jul 13, 2014.
  1. sain
    sain Junior Member
    Akron, Ohio
    How to use fan without A/C in 2005 Prius? I could not find any instructions in the manual!
  2. JC91006
    16,482
    8,400
    You turn off ac by pushing the ac button while fan is on. This is on the climate controls on the center multifuntion display. This also will turn in ac if pressed again. Press to turn on, press to turn off. Same button
    49,505
    just hit the fan up/down button. if the a/c comes on, it's because the auto button had been depressed previously. just hit a/c to shut it off, or auto if necessary. you can't use auto if you want manual control of the hvac system.
  4. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    The A/C button is the on/ off switch for A/C, fan will stay on, if on.:)
