How to verify OEM spark plug compatibility Prius Gen3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Dec 6, 2025 at 12:48 PM.
  1. gatorback
    gatorback Junior Member
    33
    I am seeking confirmation from owners that I have installed OEM spark plugs in their Gen3 Prius. I believe OEM is Denso SK16R11. Possibly the Denso SC20HR11? Has anyone installed the Denso SC20HR11
    It is unclear to me if the Denso SC20HR11 is a suitable OEM replacements for my Gen3 Prius. As I newbie, I am inclined to use OEM unless Mendel or other senior member recommend otherwise.
    I understand that Denso manufactures spark plugs in China / USA: is there a preference for spark plugs made in Japan?
    Google Indicates:
    For a 2010 Toyota Prius, the recommended Denso iridium spark plug is the
    SC16HR11, also known by Denso part numbers 3499, SK16R11, or the OEM Toyota number 90919-01275, which supersedes the older SC20HR11 specification and offers long-life performance for daily driving.
    Key Denso Part Numbers:
    • SC16HR11 (or SK16R11): The modern, recommended long-life iridium plug.
    • 3499: The retail number for the SC16HR11 plug.
    • 90919-01275: The official Toyota OEM part number for these plugs.
    eBay indicates the seller indicates SC20HR11compatibility: 4Pcs New 90919-01253 DENSO Iridium Spark Plugs SC20HR11 3444 for Lexus Toyo | eBay
    Toyota indicates part number #90919-01275
    Spark Plug #90919-01275 | Autoparts.toyota.com
    #1 gatorback, Dec 6, 2025 at 12:48 PM
  2. Hayslayer
    Hayslayer Active Member
    397
    227
    DO NOT purchase spark plugs from ebay or amazon. There are just too many counterfeits out there.
    get the 3444 plugs from RockAuto.com they're less than $10 each and will be actual denso plugs, not some chinese imitation.
  3. gatorback
    33
    #3 gatorback, Dec 6, 2025 at 1:38 PM
  4. Tombukt2
    Tombukt2 Senior Member
    12,957
    2,325
    Durham NC
    I used the twenties in my cars down here in the southeast United States where it's really hot most of the Year always have most all toyz come w 16 HR or did forever . I always used the 20 since working at dealer down here . I use the long life model of whatever plug series I'm using at time denso. Makes a bunch . Fine wire racing etc .
  5. gatorback
    33
    What is the difference between the 16HR and 20HR spark plug? Does the 20 somehow last longer? perform better? This car is driven in Hotlanta and Florida.
  6. Mendel Leisk
    41,413
    Can't remember where I heard it, but the story was the 16's are a slightly hotter plug, ie: they'll burn off deposits better. The owner's manual says 20's, but Toyota revised, presumably due to plugs building up deposits. I had the 20's for 12 years, looked virtually new when I pulled them after 12 years (and 95k kms), replaced with the 16's, per Toyota's recommendation.
    I'd just go with the Denso 16's, that's the recommendation.
    Sort of the exception, but this time round the dealership parts department was actually cheaper than my usual local automotive go-to place. Are you near a dealership?
  7. gatorback
    33
    Good to hear from you Mendel. Thanks for the interesting explanation. Yes, I am within 15 minutes of a dealer. At $4 per plug: I thought these were a good price: 4PCS GENUINE IRIDIUM SPARK PLUGS 90919-01275 FOR TOYOTA SCION LEXUS SC16HR11 | eBay
    Tombukt2 likes this.
  8. Mendel Leisk
    41,413
    Good price, but maybe counterfeit?
    FWIW, I paid $16.50 CDN apiece for mine, in 2022, through dealership. The Toyota part no (it's the denso, just in different box) was 90919=01275.
  9. Leadfoot J. McCoalroller
    8,077
    7,559
    Pennsylvania
    2018 Prius c
    StarCaller and Brian1954 like this.
  10. ChapmanF
    18,154
    Choosing a hotter plug improves burning off of deposits, at the trade of a lower safety margin from pre-ignition (the hotter plug tip may ignite the mixture before the spark is timed to occur). That's what makes the choice a trade-off, and not just a simple "get hotter plugs, they'll stay cleaner" rule.
    The language and the numbering are tricky. Denso uses lower numbers for hotter-running plugs (so 16s run hotter than 20s). Some other manufacturers use an opposite numbering convention.
    Denso uses the term "low heat range" (and a low number) to mean slower heat dissipation toward the plug shell—meaning a plug that stays hotter. They use "high heat range" (and a high number) to mean faster heat dissipation toward the shell, meaning a plug that runs cooler. So in Denso literature, "low heat range" means a hot plug, and "high heat range" means a cold plug.
    NGK avoids that mess by not even using terms like "low heat range" or "high heat range"—they say "hot heat range" or "cold heat range" (respectively!), instead.
    Heat Range | Basic Knowledge | SPARK PLUG | Denso
    Understanding Spark Plug Heat Range - NGK Spark Plugs
  11. Tombukt2
    12,957
    2,325
    Durham NC
