How to wiring the daylight running light ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MSF1344, Jan 26, 2020.
  1. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    I bought a imported Prius which hasn't got a DRL so I bought a aftermarket one which has a indicator on top and drl on bottom so I need a help to wiring this up so when I start the engine the DRl is starting to work .
  2. PriusCamper
    PriusCamper Senior Member
    13,022
    5,292
    Pacific Northwest, USA
    Not clear on what you're saying here... Sounds like you're trying to find a 12v wire to tap into that's only on when the car's engine is on. That shouldn't be too hard to find with a test light. Then you just need to make sure the 12v wire you tap into doesn't confuse anything by drawing more current than it used to.
