How Will The Corn-based ethanol Blend Affect Prius Engine?
Discussion in 'Gen 2 Prius Main Forum' started by Sid, Apr 21, 2006.
  1. Sid
    Sid New Member
    284
    Pennsylvania
    I was reading an article about the anti-smog gasoline blend using corn-based ethanol, I was wondering how it would affect the Prius' engine?
    Article URL: ARTICLE
  2. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    Any idea what % of ethanol they'll be blending into the gasoline? I think that up to a certain %, the ethanol has no negative effects on regular gasoline-burning engines. If it's over a certain %, the engine has to be modified to accept the larger amount of ethanol present in the fuel. Or something like that...
  3. jchu
    jchu New Member
    1,063
    Nampa, ID
    <div class='quotetop'>QUOTE(Rancid13 @ Apr 21 2006, 07:13 PM) [snapback]243406[/snapback]</div>
    Specifically stated in the owners manual, the Prius can easily handle up to 10% ethanol. In fact, I seem to remember they recommended it as part of the green thing.
    As an aside, as long as the primary/sole source of ethanol is corn, the flexfuel E85 thing is more of a farm support for the corn growing farmers rather than a true alternative to oil. Figures certainly vary but even the best estimates note a minimal net positive in energy produced in ethanol vs. energy used in oil. This has been covered elsewhere on PC. Also interesting interview on Talk of the Nation on NPR on the subject of the US based "Corn Economy" .
  4. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Yes, it can handle 10% but it is still hard on the engine lifespan!!!
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Anyone know what the BTU rating of summer fuel will be with Ethanol instead of MTBE?
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(huskers @ Apr 21 2006, 09:27 PM) [snapback]243451[/snapback]</div>
    No, it's not hard on the engine. Ethanol has lower power per volume than gasoline, so you get a bit lower mpg, but it is fine for engines when designed for it. One of the main problems with ethanol is that it can desolve some rubber seals and tubes if they are not the correct type. Obviously, 10% ethanol engines have the proper types of rubber.
    Tom
  7. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    I have 111,000 miles of Prius experience with E10 (the 10% ethanol blend) with my 2 Prius over the past 5.5 years.
    It's no big deal. MPG goes down a little. Horsepower goes up a tiny bit. Emissions are very clean.
  8. genalex
    genalex Member
    265
    Jersey suburbs of Phila.
  9. Sid
    Sid New Member
    284
    Pennsylvania
    Thanks all for the responses! I feel less worried now, at least about that :D
  10. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    <div class='quotetop'>QUOTE(john1701a @ Apr 21 2006, 10:19 PM) [snapback]243471[/snapback]</div>
    How much does MPG go down? Are we talking 1 or 2 mpg's or more?
  11. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(paprius4030 @ Apr 22 2006, 10:38 AM) [snapback]243614[/snapback]</div>
    E10 contains 3.4% less energy than straight gasoline. So, your mileage should go down between 3 and 4%.
    How many MPG that is depends on what mileage you're starting with.
  12. paprius4030
    2,077
    296
    York,Pa.
    <div class='quotetop'>QUOTE(Tempus @ Apr 22 2006, 12:19 PM) [snapback]243651[/snapback]</div>
    Well that stinks LOL, I want every mpg I can get out of my Prius. From what I understand, us here in The Poconos are right on the edge of the area that will be converting over to ethanol. Only the Phili area distributors will be switching over, so the gas stations that have distributors north of Phili won't. I hope that's the case so I can stick with the MTBE gas and get all the mpg's I can get.
  13. Tempus
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(paprius4030 @ Apr 22 2006, 12:37 PM) [snapback]243657[/snapback]</div>
    I plan on going on a cost basis. I don't care about miles per gallon. From now on I'm into BTUs/Mile :)
    Whatever has the lowest per-BTU cost will be the most efficient.
    I Ranted about it the other day.
    I live in Washington DC so I can get E10 in Maryland or MTBE in Virginia, assuming they don't shift everything in the area to E10 to simplify distribution.
