How would I test an engine at a PICK AND PULL yard...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Allison Meggison, Nov 14, 2019.
  1. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
    I'm wanting to look at a couple engines nearby on compatible prius' but I'm not sure how I would test it without a key and most likely lots of other missing parts vital to starting an engine. Would I need to bring a starter, a battery and a few other things to rig it myself?
  2. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    You can’t. They don’t have normal starters.
    Either cross your fingers or buy from a reputable company
    -Spiral
    Robotprince and edthefox5 like this.
  3. ETC(SS)
    7,355
    Most places that sell used engines will guarantee them for at least a little while (DOA warranty.)
    If the the place is too sketch to back up what they sell, then you're going to have to satisfy yourself with a physical exam, and truth be told you can probably determine rather quickly what kind of life the donor car led by running the VIN through all of the usual tools.
    You might get lucky and find...say, a 2015 with 30,000 miles and a verifiable service history that was totaled in a rear-end crash but that type of engine is going to probably get snapped up by a repair shop for top $$.
    Since you're in the California, I'm guessing that there are quite a few donor vehicles available locally, but in the end, how finicky do heart-lung transplant recipients have a right to BE?
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    + you could turn the engine via the crankshaft manually, to see if it has seized. Asides that, no way you'd know unless it is in the car.
    PriusGuy32 and Mendel Leisk like this.
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Be aware that miles written on the engine could be marked down to make you “believe” those are “actual” miles driven.
  6. bisco
    52,391
    at least with a guarantee, you only have to remove it and replace it again, easy peasy
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,499
    Taylors, SC
    I'd bring an oil filter cap wrench and pull the oil filter to see if there is any debris caught from the oil sump. I'd also go over the filter with a magnet to see if there is any metal there.
    Basically, you get what you pay for. You want cheap; you probably get an engine with many miles.
    A fully rebuilt engine might be the best way to go.
    mjoo likes this.
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Buy an engine from a wrecked car, not a flood car. Make sure it was a rear hit, not a front hit. Don’t ask me how I know...
    If it is a low mileage engine (<75k or less), reseal the timing cover, replace the water pump and replace the thermostat before installing.
    If it is a higher mileage engine, replace the head gasket before installing.
    iPhone ? Pro
  9. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I have always preferred rebuilt engines. O rebuilt all the engines of my clients. They last much longer, and you're even sure of the internals.
    Georgina Rudkus likes this.
  10. Georgina Rudkus
    3,513
    2,499
    Taylors, SC
    I agree with you that they are worth the extra money.
    Dxta likes this.
  11. Robotprince
    Robotprince Junior Member
    Hollywood, Fl
    2015 Prius v wagon
    Take all the spark plugs out and run compression on all 4 cylinders by turning the crank shaft with a large ratchet. If your average difference is within spec, that's good #1. Next drain the oil and examine it and the filter. If you see a bunch of metal shavings or chocolate milk it's a no go. Lastly you can put a camera in the cylinder and see its condition.
  12. Mendel Leisk
    41,905
    You can do that? A slow crank will work, build up pressure fast enough? Interesting. (Not trying to be sarcastic, just never thought of doing that.)
    Tim Jones and Robotprince like this.
  13. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "A slow crank will work, build up pressure fast enough?"
    Dubious, at best. Dubious, unless of course you are the Hulk...
  14. Robotprince
    Hollywood, Fl
    2015 Prius v wagon
    Hotwire the starter with a car battery haha
  15. ChapmanF
    18,547
    at about 250 rpm, which is kind of the standard 'starter' speed expected for compression tests, and I think also the speed you get if you use Techstream to tell a Prius "crank the engine for compression test please".
    If you have a spare four-cylinder engine around the house to practice on, you can build up your 250 rpm ratcheting technique until you are in shape to go out to the pick-n-pull yard and do it for real. Maybe also make some money getting the pick-n-pull staff to bet you can't do it.
    Hmm, maybe a starter rope from a lawnmower, wrapped around the crank pulley....
    If you take a leakdown tester with you, there's a test that will give you the same info and you can do it on an uninstalled engine. You do need to turn the crankshaft 3 or 4 times to position the valves for each cylinder's test, but you don't have to crank it fast. And you need an air compressor, or a tank of air you can fill up first.
    Prius engines are easy to turn. You can spin the crank to each cylinder compression TDC by hand. But you will want a longish wrench to hold the crank in that position when you apply the air.
  16. Mendel Leisk
    41,905
    That sounds like a plan. (y)
    Unfortunately though, I have an overactive imagination, keep picturing this guy:
  17. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    That sounds like all of us.
  18. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Long process. If it were an Otto engine with a starter, then YES, to find out if engine has seized.
  19. ChapmanF
    18,547
    A Prius engine normally turns easily by just your hand on the crank pulley. Makes finding out if it's seized pretty straightforward.
