How you know it’s spring as a Prime owner
Discussion in 'Prime Main Forum (2017-2022)' started by Storm88000, May 12, 2022.
  1. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    4DB94687-BBA7-47B9-8943-08FCF9A3AA79.jpeg 33.6. That’s nothing. I’ve seen it as high as 36.6. I know I know, it’s really a “guessometer” but I still like seeing it rather than 24-26 in the dead of winter
    51,155
    i'm up to 12! :cool: but winter just ended, and summer began today :rolleyes:
    Tideland Prius likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    In my case, springtime is when I no longer need to use A/C (for heating). I almost never use A/C for cooling, so the guess-o-meter range jumps even more significantly. If you turn off the A/C, your guess-o-meter would have been around 36 miles.
  4. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Plugged in again for a bit - 34.1.
    Salamander- do you mean turn off the AC when driving ? I actually didn’t think I had it on
  5. Salamander_King
    11,009
    8,935
    New England
    See the difference in the icon? The top is a prediction of the EV range with A/C on, and the middle is a prediction of the EV range with A/C off. The difference is usually 1-3 miles depending on how hard A/C is predicted to work for your setting and temperature. You can also see those two different Guess-O-meter EV ranges on the Drive Monitor 2 in the MID if you toggle the screen. (shown on the bottom photo for example). I don't use the Guess-O-meter on the HSI (just SoC %), so I don't remember well, but I think it toggles between those two icons depending on your HVAC setting. If you tun ON the A/C, then it will show with A/C on, and if you turn it off it will show wth A/C off.
  6. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Now I see it. Got it. Thanks
    Salamander_King likes this.
  7. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Earlier yesterday in the sun— highest I’ve ever seen it was 36.8 I believe D505762F-31FC-4C48-96B0-42668646CAA3.jpeg
  8. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Mine showed 37.4 range this morning. Love it
    Tideland Prius and Storm88000 like this.
  9. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Wow. Impressive !
  10. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    I know it is spring when mine stops blinking when it gets to 37 degrees.
    Storm88000 and lbligh like this.
  11. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Highest # since summer 2022
    pghyndman likes this.
  12. BlueMagnet
    BlueMagnet Member
    50
    26
    San Bruno, California
    2023 Prius Prime
    SE
    You guys are lucky. My highest ever was 28 since I live right next to the Pacific Ocean and it's always cold.
    And I was so happy with 28.
    Storm88000 likes this.
  13. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    36.8 highest I ever had.
    It seems to be a certain set of circumstances that allows that. A certain temp and just enough sun, but not too hot or too much. Haven’t figured it out just yet above the obvious warm weather = higher numbers
  14. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Well, today I just absolutely crushed my all time record. I was stunned. Charged during the day low 80s outside. Wow. Just wow.
