HSI for Gen II with Arduino and CAN-BUS Shield
Discussion in 'Gen 2 Prius Accessories & Modifications' started by alexmol, Apr 15, 2011.
  1. alexmol
    alexmol Junior Member
    Portugal
    Hi!
    I'm developing an HSI bar for the second gen using an Arduino and the CAN-BUS Shield.
    Hardware is just the Arduino UNO, Can-Bus Shield, 2x16 Serial LCD Display and a OBD Cable.
    I'll post the Arduino code later here. For the moment I only read passive CAN messages.
    I've developed the graphical part using only 8 custom caracters, which was the most difficult part so far.
    The bar currently shows:
    Braking pedal - from 0 to 20% fills the regeneration bar on the left
    Gas-Pedal: dinamically fills the main bar, the first half is electric-only mode (if the car is warmed up), second half is from ICE ignition till about 2200RPM, power section if from about 2300 rpm till 65% gas-pedal position.
    Battery current, in Amps
    Cooling liquid temperature, in degC
    RPM
    Pictures and videos coming soon.
    Best Regards
    Alexandre
    3 people like this.
  2. alexmol
    Portugal
    Here's a video of the first stage of development, basicaly like a scangauge, where it reads gas-pedal, brake-pedal, rpm, battery current and cooling liquid temperature.
    I can't post links yet (new in the forum) so just go to youtube and search for:
    Desenvolvimento de uma barra HSI para o Prius 2G
    (sorry the video is in portuguese, I'll try to make an english version if this thread gets popular)
    Best Regards
    2 people like this.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    That looks really nice!
  4. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Custom Fonts are just tedius having done them before for my Ford Info Panel.
    Looks great! Thanks.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
  6. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    I cant see the videos, but i'm very interested!
  7. alexmol
    Portugal
    I'll post the links to the videos later, when I have access to the posting link functionality, I'm still a junior member here :rolleyes:
    Or maybe one of you senior members can post the links...
    I've now tested the HSI bar with good results but I'm still missing some things.
    One of them is B-mode. How should the CHG bar behave when in B-mode.
    The drag regeneration is greater, but besides that should the bar behave differently than in D-mode?
    How does it work on the 2010 Prius?
    How would you like to work?
    Regards
  8. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    PART 1:
  9. BrettS
    BrettS Active Member
    290
    136
    Orlando
    That looks like a very interesting project. The HSI screen is the one that I leave up 99% of the time when I'm driving my 2010 and I've found that it provides the best information for me.
    I can answer some of your questions about how the CHG bar behaves in a 2010. The CHG bar is based on the amount of charge being generated by the regen system and is not based on brake pedal position. For example, if you're traveling at 40MPH and you press the brakes you'll see the CHG bar fill up. As the car slows down you'll see the CHG bar start to decrease (even though you haven't changed the position of the pedal) as the car gets under 10MPH or so and starts to switch to the friction brakes you'll see the CHG bar drop to almost 0.
    If you're driving along and lift your foot off of both pedals the CHG bar expands to about 1MM as the car introduces a very small amount of regen instead of actually coasting.
    If you put it in B mode and lift your foot off of both pedals the CHG bar will be about 2 or 2.5MM long as the car introduces more regen to slow it down faster.
    Like I said, I've been driving my 2010 for some time using the HSI indicator and there are a few things that I wish I could see that are not shown on the 2010, but I think you've covered most of them with your device. I'd most like to see the amount of current going to or from the battery as well as the ICE RPM. The coolant temp is good too.
    I'd also like to see an indication of whether the ICE was on or not. Usually I can tell by looking at the MPG display... if it's pegged at 100MPG then most likely the ICE is off (although sometimes coasting at a high speed with the ICE on will also peg it at 100MPG) It's also impossible to tell using this method when the vehicle is stopped. In that case it always displays 0MPG whether the ICE is on or not. Although, I suppose with your device you can tell if it's on or not by looking at the ICE RPM number.
    The other thing that might be interesting to do with your display would be to have the CHG bar work all the time and not just display the regen charge. On the 2010 when the ICE is on and the generator is ingaged to recharge the battery it still doesn't show anything on the CHG bar. It might be nice to see when the battery is being charged and how much power is being provided by the generator.
    hope this helps,
    Brett
  10. alexmol
    Portugal
    Thanks for all the info Brett!
    With my device I can easily see if the ICE is off or in high speed coasting mode by looking at the instant RPM (lower right). If its around 960 then it's in that mode.
    By watching the instant battery current (lower left) I can see how much current is beeing fed into the battery when in recharging mode or during regenerative braking.
    Basically I think I can get all the info you would like to see, although not all in graphical mode.
    My ideia for the CHG bar would be to aid the driver in not using the friction brakes...
    I'll try to program the CHG bar to work with current flowing into the battery and see if it's much different from my actual implementation.
    Also I still have some doubts about the behavior of the CHG bar in B-mode during braking.
    Above 22mph if you engage B-mode the ICE will rev to do engine braking. In that condition how does the CHG bar behave?
    Many thanks!
    Alex
  11. alexmol
    Portugal
    Here's another video showing sleep mode and dimmer functions.
    It also shows EV mode detection and my prefered placement of the LCD
  12. alexmol
    Portugal
    Here's the first English spoken video o the current status of my hsi bar with Arduino.
    pashko90, babybird, F8L and 3 others like this.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    This is awesome. How do I get one? :d
  14. cwa
    cwa Member
    Colombo
    Hi Alexandre,
    This is one of the best interfaces I have seen ever. Do you plan to rebuild more units? Even as it is, this will be very useful to many prius GenII users.
    Sorry for this dumb question, but is this interface depend on OBDII? The reason is My Prius is GenII, but JDM. It does not recognise OBDII devices.
    CWA
  15. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    When you get that project finished be sure to contact Danny ([email protected]), the Prius Shop and PriusChat owner, I'm sure he'd be glad to sell them in the shop if you can produce enough. I think there'll be a really big market for them in the Gen II crowd.
    NortTexSalv04Prius likes this.
  16. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    It looks like it can also be a DIY project. The parts cost about $100.
    Alexandre, are you getting the power from the ODBII port? Will someone with soldering skill be able to do this project? My understanding is, connect all the pieces and then program it through a USB cable.
  17. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    So it look slike this has a couple of cool features lacking in the SGII but the SGII has a lot of features this lacks. Can the two be used at the same time with an OBDII splitter?
  18. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    After further research, it looks like all the parts plug right in, without any soldering.
    I am tempting to buy the necessary hardware if Alexandre is so kind to share his work.
    F8L, this thing can have all the features SGII have plus more since the firmware is open source. I believe you can even have a bigger color LCD screen! However, the current example firmware uses 2x16 screen.
  19. telmo744
    telmo744 HSD fanatic
    2,179
    768
    Portugal
    Olá, Alexandre!
    Keep up the good work!...
  20. alexmol
    Portugal
    Hi all!
    Thanks for the comments.
    I'm still fixing 2 problems, after that I can sell the device if enough hardware is available. Before selling I still have to get some nice boxes for the controller and the LCD.
    Still to fix:
    -Standby current is about 50mA, too high for "use and forget" as it can deplete your 12V battery if you don't use the car for a long time. This will probably lead to some hardware changes making it less friendly to those who want to build one but are not familiar with electronics.
    -LCD will withstand summer temperatures inside the car?
    The current version is also an open source project. Anyone can buy the parts and build it, no tools necessary, just a USB cable and the Arduino software to upload the code. I'll post a link to the code later.
    If you plan to build one be advised that the code was developed for the sparkfun 2x16 serial LCD, it will only work with that because of the programming of the custom characters necessary to draw the bar.
    If you use another brand of serial LCD 2x16 you will need to alter the code for programming the custom characters (minimus 8 custom characters, each character 5x8 pixels).
    It gets the CAN-BUS signals and 12V from the OBD port. Should work on all 2nd gen Prius and even on 3G (haven't tested yet).
    Hope I answered all your questions!
    Regards
    Alex
    macandlinuxuser and babybird like this.
