HTC Droid connectivity
Discussion in 'Gen 2 Prius Audio and Electronics' started by Iamjo20, Apr 29, 2010.
  1. Iamjo20
    Iamjo20 Member
    259
    I just bought a new HTC Droid Incredible - I have it paired with the Nav system on my Gen 11, 2008 Prius Nav System; however, it will not connect...please advise............
    Jo
  2. Brentley
    Brentley Junior Member
    28
    Oakland CA
    Is the droid set to allow bluetooth? my wife has a moto droid and it pairs fine.
  3. Iamjo20
    Iamjo20 Member
    259
    I just got it paired and connected - works great!!!!!
    thanks!!!
  4. Don-RI
    Don-RI Member
    153
    Cumberland, RI
    Anyone have any luck with the HTC Incredible and a 2004 Prius? The phone & car see each other, the phone asked for a password, which I enter, the message reads "pairing" briefly..... and then the message disappears. They don't see each other. Repeated attempts, same process & result.
  5. leftcoast
    leftcoast New Member
    Napa, CA
    I have been able to connect my Droid Incredible to my 2006 Prius w/Navigation, but cannot get it to connect to my 2008 Prius. Is there a trick to this?
  6. loonyhiker
    loonyhiker Junior Member
    16
    I haven't been able to get my Droid Incredible to connect to my 2007 Prius. Hope someone can help both of us.
  7. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    You have to make sure that the pairing with the 2006 is either out of range or disabled before you try with the 2008. the droid will only pair and connect to one device at a time and will default to the one it paired with first if it is in range of both, unless you go into settings and disable the first one.
    You only have to do this when setting up the second device.
    The phone will then pair with whatever car you are in.
  8. Supreme
    Supreme Hypebeast
    182
    Philly
    I can connect and make calls no problem with my droid eris, just can't transfer my phonebook.
