  1. kotter.jeff@ gmail.com
    kotter.jeff@ gmail.com Junior Member
    Bradenton
    I am activating the hud display thru the settings wheel. My 2018 Prius Prime Advance will let you adjust the brightness but will not let me raise the hud. Thank You for your assistance.
  2. Tideland Prius
    16,155
    The height adjustment can be found by turning off the HUD then turning it back on and immediately use the D-pad on the right side of the steering wheel to adjust the height.
  3. priusman15
    priusman15 New Member
    Frankfurt
    2023 Prius
    To locate the height adjustment setting, start by disabling the Heads-Up Display (HUD), then re-enable it. Immediately after turning the HUD back on, utilize the directional pad located on the right side of the steering wheel to modify the height as desired.
