Huge MPG variations
Discussion in 'Gen 5 Prius Main Forum' started by TheGodX, May 1, 2025.
  1. TheGodX
    TheGodX New Member
    Austin
    2024 Prius
    I recently made a trip to Dallas from Austin and back. Going to Dallas and drivng within Dallas, 264 miles i filled up with 4.5 (top off) gallons before starting return trip that comes out to be 58.66mpg. After coming back to Austin top off again after 228 miles and needed 5.26 gallons which comes out to be 43.35mpg.
    All this with cruise set to 72mph and 3 people in the car with AC on.
    I did drive through some stop and go traffic going to Dallas and no traffic on way back as it was late in the night.
    But that's just too mch of a discrepancy that i can not explain. Any idea why fuel efficiency might be so different on essentially same route going one way then comng back?
  2. PriusCamper
    PriusCamper Senior Member
    12,764
    5,173
    Pacific Northwest, USA
    If you had a truck that got 10MPG and sometimes it only got 9MPG you wouldn't think much of it... However that would be a far more drastic fluctuation in MPG numbers than what you're experiencing. As in it's totally normal for a Prius to be fluctuating with the MPG range you're describing.
    There's so many things that can change MPG. And number one reason people get bad MPG on an otherwise fully functional vehicle is tire pressure... Pump those tires up higher than normal and you'll definitely see an MPG improvement.
    GcinFl likes this.
  3. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm going to go with:
    Primary factors:
    - Your trip from Dallas to Austin(43mpg) was nearly completely at 72mph. You're getting little to no extra benefit from the hybrid system at constant highway speed.
    - Your trip from Austin to Dallas included around 40 extra miles of city driving around Dallas. You got the full benefit of the hybrid system in that part of the trip. EV driving time, ICE off at stoplights, etc. You also got a mild boost from the slower traffic on the way in.
    Secondary factors:
    - You don't know if the two gas pumps filled your tank to the exact same level. The pump in Dallas may have slightly underfilled(inflating your mpg) and/or the pump in Austin may have slightly overfilled.
    - Wind speeds could have been different. If you had some level of tailwind on the way to Dallas and/or a headwind going to Austin, that could have made a big difference.
    - Temps could have been different. This is the least likely, but it's possible the climate controls needed more power on the way back(doubtful, but there's a tiny chance)
    Austin is technically higher in elevation than Dallas, but it's by such a tiny amount(~10') that I can't believe it could be a major factor. Still, the shape of the terrain could have possibly had an impact if any hills in between tended to have steep slopes on one side and gentle slopes on the other.
    Camper is also correct that a Prius(esp. an LE) is going to see bigger fluctuations than most any other car. A 20% difference in a 20mpg car is 4mpg. The same 20% difference in a 50mpg car is 10mpg.
    PrimeDan and Trollbait like this.
  4. sclevine
    sclevine Active Member
    161
    155
    Northeast Florida
    2024 Prius
    Agree with replies - in my opinion:
    - wind is a huge factor. On a road trip, wind at my back I get 55 easily, but headwind it will be in the 40s for sure.
    - local driving in Dallas will most definitely give you a higher MPG than 72 on the highway, so since you included the local driving in your one-way trip, yes that trip will be higher mpg.
    - in my opinion, once you get above 68 or so, there is a hit to the MPG, so at 72 cc, you are not at speed to get optimal mpg.
    43.x seems low, but if your tire pressure is on the low side, you had a headwind, and was going 72 the whole way, it is reasonable.
  5. TheGodX
    TheGodX New Member
    Austin
    2024 Prius
    I keep an eye on my tire pressure, they are inflated correctly to be over 1psi than what the label.on door jamb says, each.
    Driving against wind might be true on return trip but will it cost 15mpg!?
  6. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Depending on the wind, yes.
    At 72 mph, 5th gen LE requires ~22 hp. Add a 10 mph headwind and that jumps to ~30 hp. (These are with 150 lb driver; with two more passengers these figures will be slightly higher).
  7. AddMoreGas
    AddMoreGas Junior Member
    87
    51
    57
    Dallas
    2024 Prius Prime
    XSE
    Houston or Austin towards DFW there is always a significant tail wind. Going back down south, it turns into a headwind. I have noticed the same.
  8. Leadfoot J. McCoalroller
    8,088
    7,568
    Pennsylvania
    2018 Prius c
    "AC on" doesn't tell us much, because we don't know how hard it was working at any point during these trips. No fault of yours- that's the beauty of automatic climate control. It just works as much as it is needed.
    We've observed enormous swings in MPG just from a few degrees difference in outside temps, because if you don't need much AC you get a major fuel savings. Spring and fall can give you intra-day temperature swings that take you in and out of high-demand cooling mode, which make the differences really stand out.
    Trollbait likes this.
  9. Trollbait
    12,539
    Gasoline blend is also a factor. Reformulated gasoline(RFG) is lower polluting and required in some areas. It also tends to yield lower fuel economy.
    Houston is a mandatory RFG zone. Austin might use it, but only during the summer. So a mix of lower energy gas fueled the trip home to Austin. Though I put the difference mostly on the difference between constant 72mph and lower than 72mph with some city driving thrown in. The average speed of the EPA highway test is 48.3mph and maxes out at 60mph. Cruise above that, and don't expect to reach the window sticker number.
  10. Winston Smith
    Winston Smith Active Member
    359
    241
    OH
    2024 Prius
    LE AWD-e
    Weather has been the variable to which I would attribute most of the mpg differences I've experienced. Heavy rain with temperatures barely above freezing have gotten me mid 40s, while some dry warm days on the same road have given figures (as shown on the car's own read out) so high I doubt their accuracy.
  11. ChapmanF
    18,204
    I approve of the principle of comparing an equivalent fluctuation in a lower-MPG car, but I'm not fully on board with the math in this example. 10 MPG : 9 MPG is not a "far more drastic fluctuation" or even "more drastic" at all. It's equivalent to 48.17 : 43.35, which is less drastic than the OP's 58:66 : 43.35.
    58.66 : 43.35 is more like 12 MPG : 9 MPG.
  12. PriusCamper
    12,764
    5,173
    What's interesting is Michelin tires will say 45psi and other tires will say 35psi even thought there's nothing in the design that makes the Michelin more able to handle an additional 10psi... Also the type of roads and type of weather you're using plays a huge role in what tire pressure is best. And the sticker on your door doesn't correlate to any of that.
    I always say add a pound or two of pressure periodically and once it gets too high you'll notice slightly less traction when accelerating from some stop lights, which is when you want to lower the pressure a little. Basically the rougher the roads, the lower the tire pressure needs to be.
