Human/Prius Centipede
Discussion in 'Gen 3 Prius Main Forum' started by Tommy West, Oct 22, 2023.
Tags:
  1. Tommy West
    Tommy West Junior Member
    51
    In a Prius
    Hello more purty peepz!
    I need to know, hypothetically of course, if I we're to have two Priuses connected together and I ran a wire from where the signal comes into the little motor that controls the throttle to the same spot on the rear car would this also activate the throttle of there rear car exactly the same way so that when you press the accelerator pedal on the first car it would control acceleration of both cars simultaneously?
    I made a video also
    https://youtube.com/shorts/Iqcy1CjNLAU?si=6twJL9qJxKM9E5ob
    #diginomad
  2. ChapmanF
    17,326
    You'd be better off using the wire to take the signal from the go pedal to the inputs of both cars' power management control ECUs, and let each ECU control the throttle of its own car. I suspect you could get away with the pedal going to two ECUs' inputs without having to worry about input impedance getting too low.
    Even so, there would need to be a whole lot more to the story. Are you sure you don't just want the Prius in back to have adaptive cruise?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    This is catastrophe waiting to happen.... physically and financially.... I can't even begin to think of the liability involved with this going south and killing someone. Wonder what law enforcement is going to say when they see this rig......
  4. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    duplicate
    #4 TMR-JWAP, Oct 22, 2023
  5. fuzzy1
    10,335
    Assuming the load weights are carefully matched so they will accelerate and decelerate similarly ...
    Remember that a fairly large portion of highway losses are from air drag. The rear vehicle will be doing extreme drafting, so will have very significantly reduced air drag. That means when these vehicles are controlled to put out the same propulsion power, the rear car will be continually pushing the front car.
  6. ChapmanF
    17,326
    Set the front car for PWR and the back one for ECO?
  7. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Waaay gnarly dude!!! Don’t let people here stop ya. Liability and law enforcement are just dream killers.
    Johnny Cakes and bisco like this.
  8. Johnny Cakes
    Johnny Cakes Senior Member
    1,039
    775
    Virginia, USA
    In many ways, I absolutely love this. Steering might be a bit of an issue.
    I want to see the rear hatch of the first car removed and the front windshield of the second car removed.
    And then fabricate an air-tight connection between the two cars, so that it is really one car. So the interior would be from the front dash in the first car to the rear hatch of the second car.
    Prius camping would be awesome! It would be like a two-bedroom RV.
    Parking might be a bit of an issue. There's also cooling for the second car's ICE.
    But all of these are minor problems, easily overcome, I'm sure.
  9. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    Mr. F likes this.
  10. black_jmyntrn
    black_jmyntrn Senior Member
    1,694
    395
    2013 Prius Plug-in
    well.. since you aren't trying to marry the two HV systems just the "throttle"... but wait, are they welded together? need more details. connected from to frame and the rear Prius doesn't steer? But will the rear Prius steer as well? I mean CANBUS is there, I think that's your easiest Um, way. A CANBUS controller. I never thought about it that way, my usage is using CANBUS and the throttle position to control an added rear electric motor on the rear axle of my Gen 3. To control a 2nd CANBUS vehicle with the CANBUS of the 1st vehicle, I'd have to think through that one.
  11. Tommy West
    51
    In a Prius
    I hope steering won't be an issue since I'll fasten the two cars together into one unit by welding to the frame some sort of quick connect hitch on each side.
    I need to be able to separate the two cars when I get where I'm going to do gig work like UberEATS and Doordash. And I need to connect them to move from state to state as I endlessly travel around the US. I already live in a Prius and stealth camp at hotel parking lots like where I am now 365 nights a year. After I get the synchronized cars working I'll build a foamie camper to attach to the same connections and fit in-between the two Priuses that will give me a space for virtual reality and a indoor shower and cooking area. I'll still sleep and everything else in the car.
  12. black_jmyntrn
    1,694
    395
    2013 Prius Plug-in
    you know, I think outside of the box often but I have yet to reach the space nebula region you are in. Bravo!
  13. Tommy West
    51
    In a Prius
    What i really need to know is what signal can i send to what part that will make the rear car think I'm pushing it's had pedal exactly like I'm pressing the front car's had pedal. I mean isn't it fly by wire? So where does the signal comming from the gas pedal go into? If the rear car gets the exact same signal to the exact same part that tells it the position of the gas pedal won't it throttle up the same way as the front car and if not why the heck not? Also can one Prius handle towing the other for a short time until the few of you who really know stuff can help me get this working without blowing the Transaxle right away. I only drive maximum of 55 mph. I guess I should wait until winter chases me out of Michigan and I land in Tucson or somewhere until spring. I need to finish my my 1500 ah lifepo4 battery build first so I'll have power for all the crazy stuff in adding. I have the cells just need everything else.
  14. ChapmanF
    17,326
    As suggested in post #2, the go pedal is wired to the power management control ECU. You can probably go to the rear car, unplug its go pedal, and parallel wire the front car's go pedal to both ECUs. I am guessing that the pedal's output impedance is low enough to serve two ECU inputs without getting loaded down. You'd probably want to use some heavier wire to bond the two cars' grounds together (unless your welded metal frame will accomplish that anyway). And you might want to treat the VCP1 and VCP2 lines with some extra care: each ECU will be trying to source a regulated 5 volts onto those lines, but the two ECUs could have slightly different opinions of what's exactly 5 volts.
    At the same time, post #2 was pretty much tongue-in-cheek. There is a whole lot left out of a plan like that. With the cars rigidly joined together, who knows, maybe you'd get something to work.
  15. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Because NO two cars are exactly the same, not even when new, not even if they were next to each other in the assembly line. Throw in some years of use, wear and tear, and who knows? Same reason why 2010 Prius "car A" gets 50 mpg and "car B" gets 48, even if driven exactly the same. You seem hell bent on doing it, so I hope it works out for you. I just hope you don't kill yourself or some other poor sonofagun driving down the road minding their business.
    p.s....if you're going to fake out the throttle, the brakes may be worth thinking about also. I wonder if seat occupant detection has any interaction?
    I would be surprised if you actually made it to your destination without being stopped by law enforcement. They're responsible for road safety and what you're contemplating is by no means safe. Even if you decide to just tow it, you're putting yourself and others in danger. There's a reason companies like U-Haul require minimum weight differences between the hauler and haulee.
  16. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Help me out with this one, I may be misunderstanding. The OEM HV battery is rated at 6.5ah. You're building a 1500ah battery?
    KWh = Ah x V / 1000
    =1500x202/1000
    =300+KWH
    That's a big battery. Aren't tesla batteries around 85-90?
    How will it be installed in the car?
  17. Johnny Cakes
    1,039
    775
    Virginia, USA
    A quick tailgating ticket and he's on his way.
  18. ChapmanF
    17,326
    Is it tailgating if they're attached?
  19. black_jmyntrn
    1,694
    395
    2013 Prius Plug-in
    PLAID is 100 all else is smaller in the 55-75 range
  20. Tommy West
    51
    In a Prius
    The battery is for house power since my Prius is a house that just has a different front yard every day. I have refrigerator and microwave and oven and obviously I need my hot glue gun so I can glue elastic inside my cowboy hats to hold the insta360 cameras that I use to film every second of my live as I travel around the country doing late night food delivery on the most dangerous and interesting places..... Doesn't everybody?!?
