Humid A/C at idle
Discussion in 'Prius v Main Forum' started by Lildevil, Jul 27, 2021.
  1. Lildevil
    Lildevil Junior Member
    30
    Omaha, NE
    My A/C will blow out humid air when at an idle for more than a minute. Is this normal? I just had the A/C evacted and recharged and it is nice and cold while driving, but when I stop at a light, it will get humid until I start moving again. It did this prior to the recharge also.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,894
    6,838
    Texas Hill Country
    Maybe the condensate drain is clogged.
    Tim Jones and Raytheeagle like this.
  3. Lildevil
    30
    Omaha, NE
    Thank you, I will check it out.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    That would be my guess too.
    But not having it on "recirculate" can make a BIG difference too.
    Tim Jones likes this.
  5. Mendel Leisk
    42,205
    Clogging of the water drain tube "might" be accelerated by mold. One thing to prevent that is to turn off AC a bit before your destination, give the humidity a chance to clear, if practical. If you're using AC round-the-clock I guess that goes out the window though.
  6. Lildevil
    30
    Omaha, NE
    The recirc is on and works fine. Thanks for the input!
