Humidity Sensor
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, Apr 16, 2018.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    I was looking at the forums and heard of the humidity sensor up next to the camera. Does anyone know what it does?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    It measures the inside humidity.
    It is a part of the heating/cooling system.
    It can turn on the "air conditioning" on low if the humidity is too high even if you have it "off".
  3. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    This car is amazing. Does everything but the dishes.
    Dudley1030 and EyePrime like this.
  4. Tideland Prius
    16,159
    It's part of the automatic climate control.
    I honestly don't know why all climate controls don't have a humidity sensor but I guess the Prius has one to better fine tune the use of the A/C compressor. (e.g. the Camry and Avalon Hybrids have humidity sensors but not their gasoline counterparts)
    Since2002 and EyePrime like this.
  5. EyePrime
    268
    115
    2018 Prius Prime
    Woah that's crazy. This car has EVRYTHING
  6. Tideland Prius
    16,159
    Almost. It's missing a GPS sun sensor that Lexus and Acura have ;) (Those will automatically increase cooling on the side of the car that has more sunlight due to either a solar sensor or GPS software that tracks the location of the sun through the sky)
    Since2002 and Dudley1030 like this.
  7. EyePrime
    268
    115
    2018 Prius Prime
    Ok, that's a little bit too much.;)
    Dudley1030 and Tideland Prius like this.
  8. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    If you sneeze a tissue pops out from the dash too!
  9. Tideland Prius
    16,159
    And that reminded me of an ad they did 10 years ago called "Human Touch"
    Dudley1030 likes this.
  10. Since2002
    Since2002 Senior Lurker
    936
    1,097
    Duluth, GA
    It hasn't been mentioned in a while but the Prime as well as the liftback have a feature called Smart Flow which senses whether the front and rear passenger seats are occupied, allowing it to avoid directing hot or cold air towards empty seats which wastes energy.
  11. sam spade 2
    7,035
    2,788
    2017 Prius c
    Sometimes newer isn't always better.
    This strikes me as overkill.
    When I am going more than a few blocks, I want the ENTIRE cabin to be heated or cooled......even if nobody is sitting in that space.
  12. Since2002
    936
    1,097
    Duluth, GA
    I would agree it would be overkill if it had no appreciable effect on energy use. I don't have the data so I have no way to prove that it is a worthwhile feature but just instinctively it seems like it would save enough energy to make the feature worth its while. Either way if you don't want it on all the time Smart Flow can be turned on and off with a push of a button. Or in models with the 11.6 inch screen its one tap on the display to turn it on or off.
